Alternator needs to be replaced.
Old Nov 26, 2024 | 12:46 PM
pman49's Avatar
pman49
Default Alternator needs to be replaced.
Hi all. Dealer wants $1700.00. I am looking for a second opinion. I have just over 86k miles on 2018 Premium model.
Old Nov 26, 2024 | 05:24 PM
ASE's Avatar
ASE
Parts + Labor breakdown ???
Old Nov 26, 2024 | 05:41 PM
mike202's Avatar
mike202
Your price is $430 at Bell, MSRP is $581 which is what dealer should be charging. $1119 for labor sounds like a lot but a search indicates that the SM says the radiator needs to be removed to do the job.
In this thread there is mention of replacing it w/o removing radiator. https://forum.ih8mud.com/threads/201...ement.1079244/
https://parts.belllexusnorthscottsda...706038110.html
Old Nov 26, 2024 | 05:48 PM
GrizzlyClint's Avatar
GrizzlyClint
Unfortunately the radiator has to get removed so that's a good amount of labor hours right there.. Though I paid about a tick under $900 at a Toyota dealer.
Old Nov 26, 2024 | 06:05 PM
pman49's Avatar
pman49
Thanks for your replies. The price I got was $575 for the part and the rest labor.
Old Nov 26, 2024 | 06:08 PM
pman49's Avatar
pman49
This quote is from a Toyota dealer in High Desert, California.
Old Nov 27, 2024 | 06:58 AM
BradTank's Avatar
BradTank
You don't need to drop the radiator to replace it, there's an easier way where you drop the sway bar.
$1700 is a sky high quote in my opinion, but that might just be what the book says and so that's what they can charge. But someone that's done a few of these could probably bang it out in an hour.
I would just make sure it's the alternator, 86k miles is somewhat low for an alternator replace on this Lexus. I would hope the battery has been tested and is not the culprit.
Old Nov 27, 2024 | 04:01 PM
pman49's Avatar
pman49
HI BradTank, thanks for your suggestion. The battery was tested and found to be ok. It's only a couple of years old. This SoCal dealer charges $225 an hour labor. Same amount for diagnostics.
I'm considering Bell Lexus for the part and an indie my son knows for instal.
Old Nov 27, 2024 | 06:53 PM
BradTank's Avatar
BradTank
I think that's a good plan. An indy shop can easily handle this job. $225 an hour is steep.
You can also get a Denso remanufactured alternator that's an OEM for cheaper, but if it were me, I'd buy a new one from an online dealer. If it were easy to get to, I'd get roll the dice on a remanufactured one, but it's a lot of labor to get to this one.
Old Nov 28, 2024 | 09:45 AM
JZZFZZ's Avatar
JZZFZZ
Do it yourself for $150 with a remanufactured Denso.
B777Pilot
Sep 13, 2022 11:39 AM
Vuongto12
Jul 14, 2021 08:24 AM
Lexnek
Maintenance
Apr 20, 2017 05:41 AM
tpjc1018
Jul 29, 2014 06:08 PM
