Help
Old Nov 13, 2024 | 03:33 PM
Whoishavik's Avatar
Whoishavik
3rd Gear
Default Help
Hi I was driving (2011 Lexus gx460)and my knee accidentally hit the central differential lock and was middle of traffic so couldn’t disengage it right away. As I was driving smoke started to come out but pulled over in time and it stopped once I was able to turn off the central differential lock. Car smells burnt but driving like nothing happened is this something I should be worried about?
Old Nov 13, 2024 | 03:59 PM
mike202's Avatar
mike202
I am skeptical that the smoke has anything to do with this. Where was the smoke coming from?
Yes, the manual says to unlock when on hard surfaces but unless you are making a lot of turns, the drivetrain would not be binding up. Where you making a lot of turns? Also why didn't you just push the button to unlock?
Old Nov 13, 2024 | 04:02 PM
Whoishavik's Avatar
Whoishavik
3rd Gear
smoke was coming from rear and I was pressing it to turn off but was flashing and had to YouTube it reversed it and it turn off and smoke went away. I was on the free way when this occurred so no turns at all which I found odd. The button was stuck and wouldn’t let me turn it off
Old Nov 13, 2024 | 04:15 PM
mike202's Avatar
mike202
smoke was coming from rear and i was pressing it to turn off but was flashing and had to youtube it reversed it and it turn off and smoke went away. I was on the free way when this occurred so no turns at all which i found odd. The button was stuck and wouldn’t let me turn it off
From the owners manual:
Old Nov 13, 2024 | 04:26 PM
ASE's Avatar
ASE
Were you "dragging" a tire ? ... if so, the tire compound can heat up pretty quick and smoke. Was it a dark(er) smoke with a burnt rubber smell ?
Old Nov 13, 2024 | 05:03 PM
Whoishavik's Avatar
Whoishavik
3rd Gear
it was a white smoke tires seem to be fine. But a distinct burn smell of rubber or sum sort
BillWill87
GX - 2nd Gen (2010-2023)
Mar 9, 2023 05:55 AM
enkerkee
NX - 1st Gen (2015-2021)
Feb 27, 2023 06:35 AM
athanato
Oct 30, 2021 06:28 PM
lexushelpw
Nov 3, 2019 01:08 PM
passnu2
Chicago Lexus Club
18
Nov 1, 2012 05:54 AM
