GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
transmission fluid change?
Old 02-23-19, 05:02 AM
av8trmech
av8trmech's Avatar
Default transmission fluid change?
was trying to get some info on changing trans fluid in my 2009 GX 470. it is a sealed unit so it is suppose to last but i recently had to replace radiator, and the new one had a faulty o ring in the trans fitting so lost a lot of fluid before i found the leak. was reading other forums about it and was wondering when checking fluid level that the temp should be at a certain degree, i have a scan tool that gives me that but have not found any info on what the temp is. any help would be appreciated.
Old 02-23-19, 06:26 AM
bgalarpe
bgalarpe's Avatar
Add fluid from the side of your transmission and follow this procedure to see if you have too much or too little.
Old 02-23-19, 10:08 AM
campfire
campfire's Avatar
The way I do it is:
  • drain the trans fluid at the pan, then put bolt back on
  • replace trans fluid with the same amount that came out
  • next, disconnect the return trans fluid line at the cooler in front and put the line in an empty jug
  • start the engine, and shut it off as soon as the t fluid starts to sputter
  • replace the same amount of fluid, repeat until clean
hope this helps. I use synthetic fluid
drkatnaga (08-28-20)
Old 02-23-19, 10:20 AM
NTH
NTH's Avatar
IIRC, fluid temp 115-131F
danno52
RX - 1st Gen (1999-2003)
04-08-19 06:11 AM
colenzae
05-22-16 02:36 PM
cwolaw
06-02-14 08:53 PM
Michael
13
11-24-13 08:59 PM
ISFer
IS F (2008-2014)
14
04-27-10 11:56 AM
Quick Reply: transmission fluid change?
