Noise coming from the engine when driving
Old Jan 30, 2019 | 08:36 AM
deeken's Avatar
deeken
Default Noise coming from the engine when driving
Hey guys I'm having an issue with my truck and need some help figuring out what it is. Here is the issues I'm experiencing; when I'm driving I hear a noise coming from the engine bay that sounds like an exhaust leak. The noise gets a little louder the faster I go. I don't hear this noise when I'm parked and revving the engine or when I'm holding down the brakes and giving the car gas. I noticed it a few weeks ago when I was on the highway. It sounded like there was another car next to me with a modified exhaust. I know this is kinda vague and hope someone can help me figure this out. The last thing I want to do is take it to the stealership as they are all crooks by me. Thanks all.
BTW, No check engine lights and it's not a failing alternator as I had that issue last year replaced, also I remember the noise it made.
Old Jan 30, 2019 | 10:21 AM
Arailt's Avatar
Arailt
An exhaust manifold leak makes a loud ticking noise when the motor is under load (accelerating). Sounds like an old farm truck.
Old Jan 30, 2019 | 11:08 AM
deeken's Avatar
deeken
Thanks, I'm hoping it's something easily fixable such as an exhaust leak. I'm hoping to get under the truck after the weather warms up a bit.
Old Jan 31, 2019 | 05:56 AM
RushNatU's Avatar
RushNatU
Are you sure its under the engine bay? There an exhaust gasket about halfway down the car between the pipes for the muffler and cat. Mine was so burnt there was hardly anything left. New gasket made the tick much quieter. I do also have a small exhaust manifold leak I can hear under acceleration if I’m next to a wall
Old Jan 31, 2019 | 02:18 PM
IanB2's Avatar
IanB2
The manifolds are a common failure point, they crack and warp and cause exhaust leaks. I hope it's not that as they are a PITA and not cheap parts. Lots of guys go with Doug Thorley headers instead of manifolds.
Old Feb 1, 2019 | 06:46 AM
Arailt's Avatar
Arailt
Yeah, I think the dealer quoted me $1500 per side for my manifolds installed. I had them both done, but thankfully they were covered under the Platinum Toyota warranty that came with my GX. I read that Doug Thorleys are a PIA to install on a GX/4Runner due to the small amount of space and welding needed to connect them to the cats/O2 sensors. I'm pretty sure they aren't bolt on.
Old Dec 11, 2019 | 07:31 AM
deeken's Avatar
deeken
Just want to give everyone an update about this issue. The cause of the noise that I thought was coming from the engine bay was actually a bad wheel bearing. I went on ebay and bought a KOYO bearing with the Timken assembly. Installed it myself in just under 2 hours. I like to take my time to make sure it's done correctly otherwise I could easily do this in about an hour. The Stealership wanted almost $1700 (plus tax) to get this done. Screw them. Got it done for 1/10 the cost.
Old Dec 11, 2019 | 11:17 AM
IanB2's Avatar
IanB2
This thread is from 10 months ago! How long did you drive on that wheel bearing making noise before you figured out what the issue was?
Old Dec 11, 2019 | 01:33 PM
deeken's Avatar
deeken
I was driving it from the time I created the thread till this past weekend. However, I wasn't driving it as much as we used to. I honestly thought it was an exhaust leak so I wasn't too concerned. Once we confirmed it was a bad bearing we didn't drive it until I replaced it. I avoided getting it checked because I despise dealerships and I'll explain why when I create a thread about it.
Old Dec 11, 2019 | 06:07 PM
RockfordRX's Avatar
RockfordRX
Please do tell....
Old Dec 17, 2019 | 09:11 PM
deeken's Avatar
deeken
Originally Posted by RockfordRX
Please do tell....
Took my truck into the local Lexus service shop by me to find out the cause of this noise my car was making. They called me a few hour later and gave a questionable breakdown of my cars issues. All totaling over $5k. The most ridiculous were $1700 to replace a wheel bearing and $1100 to replace a torn cv boot. On top of that they added on a few other services that were completely unnecessary. I told them that I did not want any work done by them and I'll be picking up my car shortly.
I ended up doing all the work they said my car needed for less than $350 using OEM parts and took less than 5 hours.
dkneumann
GX - 1st Gen (2003-2009)
Jul 28, 2017 12:39 PM
peteran85
Jul 26, 2011 05:15 PM
mann777
Oct 12, 2010 08:33 AM
RXGS
Nov 8, 2008 09:28 AM
Static911
Feb 1, 2002 03:09 AM
