Blower motor change
Old 12-11-18, 05:29 PM
Benjam1n
Benjam1n's Avatar
Default Blower motor change
Used the TYC replacement. A T25 bit was neccessary. Hard to access the rearmost T25 screw but got it done. The wire clip would not mate with the plug. Had to bend the prongs with a flathead a bit on the TYC unit to fit the clip. Unfortunately broke the "soft open" wire mount on glovebox on the reinstall. Oh well, she's a truck right? New unit works great and is quiet enough.
Old 12-11-18, 08:05 PM
IanB2
IanB2's Avatar
Did you break the actual plastic glovebox part? Do you have the broken chunk? Could it be crazy glued back together?
What were your symptoms of failure before you changed the blower motor, or did it just die?
Old 12-12-18, 04:56 AM
Benjam1n
Benjam1n's Avatar
Yes the bracket on the side of the glovebox broke and could probably be JB Welded back on. A project for another day for sure.
The old blower sounded like a bike wheel with playing cards in the spokes. Still worked fine but sounded like it was on its way out.
Old 12-12-18, 07:38 AM
IanB2
IanB2's Avatar
Could have just been some leaves got in there and it could have been cleaned out?
Old 12-12-18, 10:31 PM
Benjam1n
Benjam1n's Avatar
No leaves in there, I checked. Pretty easy fix and cost about $40 shipped on Amazon.
matts6887
RX - 1st Gen (1999-2003)
13
03-11-16 08:41 AM
solotallbo
11-05-09 03:18 PM
clfrank
Maintenance
01-27-05 04:04 PM
Invisibleman
07-22-03 05:49 AM
Quick Reply: Blower motor change
