Transfer Case Oil Change
Subscribe
Feb 9, 2018 | 11:14 AM
Hello Folks,
I searched the forum to find out about when to change my 09 GX470 transfer case oil, as my dealer said it is a sealed unit and the oil never needs to be changed. So it sounds like that was a crock, and I need to change it. My GX now has 80K on the original fluid. What interval do you folks recommend?
Thanks much!
Reply 0
Feb 9, 2018 | 11:24 AM
Wierd! My 07 TC is not sealed and serviceable. It has a drain and fill bolts. Maybe dealer was thinking of the tranny. It's supposedly sealed but serviceable. I do my TC and front/rear diff every 50k miles. WS Tranny fluid 100k miles.
Reply 1
Feb 9, 2018 | 11:49 AM
Dealers tell you the TRANSMISSION is a sealed unit and not serviceable (not true), but the transfer case is definitely not intended to be treated as such. At 80K miles I would change that fluid for sure, get new crush washers for the drain and fill plugs, make sure to loosen the fill plug 1st, and try tapping the plug with a hammer to flatten the crush washer if you can't get either loose.
Reply 1
Feb 9, 2018 | 11:51 AM
Thanks much NTH. I bet that is what the dealer was thinking. I like and am going with your TC and Diffs interval and will do asap. I'll worry about tending to the "sealed" tranny at 100K.
Reply 0
Feb 10, 2018 | 04:44 AM
I changed this fluid in transfer case and both differentials. Not a hard job at all.
Reply 0
Feb 10, 2018 | 05:01 PM
The dealer should have a 4x4 driveline service package, which is the gear oil in both diffs, the transfer case, and greasing the zerk fittings.
This thread might be useful:
https://www.clublexus.com/forums/gx-...id-change.html
Chip H.
Reply 0
Subscribe
