Timing Belt / Water Pump
Hi All. I have Lexus GX470 2007 with 96k miles on it. I am trying to decide what I should do with T-Belt and Water pump, to replace or no to replace. Also, if to replace where would be the best place to do it: 1. Local Mechanic Shop, Toyota Dealer, or Lexus Dealer? Also, any idea how much would the whole project cost, parts + labor? I live in Brooklyn NY, any suggestion where should do the service.
Thank you
Thank you
you can buy an Aisin timing belt kit with water pump, belt, tensioner, idler, thermostat, etc for around $300. I would think an independent joint would do the job for $300. so around $600-700 for total job
Don't forget the Toyota Super Long Life coolant, this is a great opportunity to do a coolant flush and refill with fresh.
I shopped around earlier this year. I called Lexus, Toyota, a few national chains and 2 Indy shops.
In the end I went to Toyota. I paid right around $800 for both water and timing belt. They were $100 more then the national chain and $150 more then the Indy shop. Lexus was way out of the running at $1500. I searched the web and it seems most dealers have some sort service coupons. A Toyota dealer down the road had a $50 coupon for the timing belt. I showed it to my local dealership and they accepted it.
I did talk with the national chains asking a lot of questions. I am sure they could have done the work, but for the extra $100, to me was worth going to Toyota. They do these 4.7's all day long versus the chains and Indys.
The best part, since I was getting a pricey service, they gave me a free loaner!! I had a new 2014 Camry that was loaded. That alone was worth it as I didn't have to rush back to get the GX, get rides back and forth, etc. Don't get me wrong, I'm sure I could have set up a rental and paid less then $100, it was just such a simple no hassle process. Hand them my keys and they gave me another set.
Definitely make a few calls around your area and check out those coupons.
Good luck!
Good luck!
Have a local indy shop do it and buy your kit here and save a bundle....
These parts are made by the same manufacturer that Toyota/Lexus buys their parts from.
PersianOne
04-25-16 11:26 AM
brock125
10-05-09 09:23 AM
