One headlight not working
My passenger side headlight is not working. I replaced my headlights with LED bulbs few years ago, and last week one stopped working. I tried replacing it with a new H-11 LED bulb but it is still not powering it on. Any idea what may be causing it and what to do? Is there a fuse that I may need to replace? I would think that the fuse controls both headlights and since one is working, maybe that's not an issue?
There are separate 10A fuses for each filament, so four in total.
(but the fog lights share a 15A fuse)
They are located in the under-hood fusebox on the driver's side. You will need to remove the plastic "beauty cover" to get to it.
Chip H.
Chip H.
Thanks for your response. I will look in the fuse box and see if any require replacement.
is250girls
Apr 14, 2015 01:00 PM
