Coil Conversion Issues - Warning Lights on Dash
Old Sep 29, 2022 | 06:21 PM
stoshzack's Avatar
stoshzack
Default Coil Conversion Issues - Warning Lights on Dash
Hi All -
On a 2003 GX470.
I just replaced both the front struts and rear air bags with regular struts and coils, respectively. I should also say that I disconnected all the sensors on the shocks. Pulled the 20 amp "Tems" fuse in the fuse panel and air bag relay under the hood as recommended.
When I start the car I get a "ABS" and "VSC" light on the dash.
Any ideas what is causing this and how to fix?
Thanks
Old Sep 29, 2022 | 06:26 PM
stoshzack's Avatar
stoshzack
Did a little digging on the forum. Think I ruined one of the wheel sensors during the install?
Old Sep 30, 2022 | 06:59 AM
stoshzack's Avatar
stoshzack
Pulled up the code. It stated that it was the left front wheel sensor. I'll try replacing it and see if it clears the codes. Must have damaged it during the install.
Old Sep 30, 2022 | 09:01 AM
NTH's Avatar
NTH
It’s a straightforward swap. Hope that solves it.
Generalb
GX - 1st Gen (2003-2009)
Sep 6, 2020 09:30 AM
user 528962307
Mar 4, 2018 08:50 AM
Vols4life
Nov 14, 2017 10:03 PM
semar
Oct 14, 2015 11:20 AM
Zoraone
Feb 14, 2014 05:03 PM
