Brakes Pulling right when applied.
Old Dec 21, 2021 | 09:47 AM
dunk50's Avatar
dunk50
Default Brakes Pulling right when applied.
Seems over the past year things have gotten a little worse. Had all new pads and rotors and when I apply brakes car pulls to the right. Now for the main reason for this post. I had a front end alignment done at a local TIRE store. Only place I could get it in. They said all went well but they were unable to free one bolt, I think camber but I don't know. If they could not get all bolts loose #1 did they do an alignment and #2 could just a bad alignment cause pulling when break applied. All tire pressure is correct and tires have been balanced twice with no problems reported. Oh and I did scrap the air ride for the bilstien 5100 conversion as described on many posts and sites. Where do I start?
Old Dec 21, 2021 | 10:30 AM
IanB2's Avatar
IanB2
Check front calipers for frozen/seized pistons, if one pad is worn and the other isn't then it's easy to spot. Very common issue on these trucks.
Old Dec 22, 2021 | 06:57 AM
chiph9's Avatar
chiph9
Like Ian said. And start looking for a better alignment shop.
Chip H.
Old Dec 23, 2021 | 01:40 PM
Davenlei's Avatar
Davenlei
I would suspect frozen caliper as well.
Isentropic
Jun 18, 2017 03:34 PM
idoke1
IS F (2008-2014)
30
May 24, 2015 08:45 PM
xbladex00
May 10, 2015 11:41 AM
carlos3366
Apr 23, 2013 07:17 PM
joedaddy1
Jul 7, 2007 08:19 PM
