GX470 Workable Wheel Offset Range
Old Jun 23, 2021 | 03:06 PM
Nixlimited's Avatar
Nixlimited
Default GX470 Workable Wheel Offset Range
I'm looking at some new wheels for my '05 GX, which are Method Racing 17x8" MR313s. They have discontinued the OEM offset version (+25mm) and now only sell a 0 offset version, which would push the wheel out 25mm. Curious if that will work without serious rubbing issues. Has anyone run a similar offset or have any guidance on what range works? Obviously, I do not want to go more inboard, but wouldn't mind pushing the wheels outboard a bit.
Thanks in advance.
Old Jun 24, 2021 | 07:22 AM
IanB2's Avatar
IanB2
It will work, you MAY have some minor rubbing on the fender liners (depends largely on tire size as well). You can drill new mounting holes in them and push the liners forward and out of the way easily.
For reference, I'm running -12mm offset wheels and 265/70/17 tires on mine, and had to do the above.
Old Jun 25, 2021 | 10:54 AM
MDSteamer's Avatar
MDSteamer
I have -12 on 17X 9 wheels, Standard size 265/65/17 Destination AT2 tires.. They stick just outside of the side steps. No spacers.
Old Jun 25, 2021 | 12:47 PM
NTH's Avatar
NTH
You’ll be fine with a 0 offset.
Old Jun 25, 2021 | 01:55 PM
offroad200's Avatar
offroad200
I'm running 0 offset with 285s and the sidewall of the tire sticks out but not the tread so you're fine.
Old Oct 29, 2024 | 05:31 PM
HipTraveler's Avatar
HipTraveler
1st Gear
Nice! What rims did you chose? Do you have any more pics you can share? I'm interested in also upgrading my rims for more "poke" but I want to keep my 265/65/17 BFG KO2s Thanks!
Parsa
Jan 2, 2023 05:55 AM
robjay0211
Jun 4, 2021 06:02 AM
bryan767
May 26, 2012 09:52 AM
TexasGS
Wheels, Tires & Brakes Forum
Oct 6, 2005 01:35 PM
