Bilstein front shocks
Old Apr 1, 2021 | 09:28 AM
asticot's Avatar
asticot
Default Bilstein front shocks
Can someone confirm the part number for Bilstein front shocks.
I am not looking for a lift and will reuse the OEM springs, but I think I need the Bilstein 4600. Everything I see online though indicates that 4600s are rear shocks.
thanks in advance
Old Apr 2, 2021 | 01:53 AM
MDSteamer's Avatar
MDSteamer
Another thought
Eibach E60-59-005-01-10
Old Apr 2, 2021 | 06:01 AM
asticot's Avatar
asticot
Originally Posted by MDSteamer
Another thought
never thought about these as I’m not looking for a lift, but I guess I would just leave it at the lowest setting. I also see some sales on these in Canada.
is it straightforward to put OEM coils on these?
Old Apr 2, 2021 | 11:15 AM
MDSteamer's Avatar
MDSteamer
Read these instructions.
https://www.bing.com/search?q=eibach...c21184f3069764
Old Apr 3, 2021 | 11:22 AM
NEPAKevin's Avatar
NEPAKevin
thanks in advance
When I converted my 07 GX470 using the Meteltech spring conversion to keep the kept the stock height used this set of
4600s. 4600s.
HTH
Kevin
Old Apr 6, 2021 | 05:06 PM
asticot's Avatar
asticot
Originally Posted by NEPAKevin
When I converted my 07 GX470 using the Meteltech spring conversion to keep the kept the stock height used this set of 4600s.
HTH
Kevin
thanks that’s what I was looking for. I ordered the Bilstein 4600s front shocks
Old Apr 6, 2021 | 05:32 PM
NEPAKevin's Avatar
NEPAKevin
FWIW, I also replaced the strut tops at the same time. Just don't do what I did and try to reassemble with the spring retaining plates in the wrong direction. The Bilstein plates face the opposite direction of the factory ones so that the springs sit inside them and apparently I was dense that night as in retrospect it should have been obvious.
pbm317
Apr 12, 2021 04:33 PM
drg0220
Suspension and Brakes
Jan 4, 2020 09:29 PM
Big Willy
Apr 28, 2010 01:50 PM
StrmRdr23
RX - 1st Gen (1999-2003)
Dec 22, 2004 08:42 AM
