J2534 Interface
Old Oct 4, 2020 | 08:19 AM
Lexus4321's Avatar
Lexus4321
Default J2534 Interface
Anyone know of a "toyota" J2534 iface device that works with Win10 64bit, but less $$ than the Drew Mongoose?
I need to venture into Techstream to try and diagnose my GX issue.
Old Oct 4, 2020 | 09:11 AM
IanB2's Avatar
IanB2
From unit 18 of the GXOR resources:
Techstream:
Getting Techstream up and running can be a bit of a pain. Hopefully this helps someone get started quickly.
Step 1: Purchase an OBD-II interface. One option:
https://amazon.com/Fangfei-Mini-Diagnostic.../dp/B06XGB714M https://amazon.com/Fangfei-Mini-Diagnostic.../dp/B06XGB714M
($20, Prime)
Step 2: Download VirtualBox for Your Operating System:
- Windows: http://download.virtualbox.org/.../VirtualBox-5.2.4...
- MacOS: http://download.virtualbox.org/.../VirtualBox-5.2.4...
Step 3: Install VirtualBox Software You Just Downloaded
- Windows: Double-Click downloaded file
- MacOS: Double-Click downloaded file, run installer
Step 4: Download TechStream Image:
- MEGA (V2! https://mega.nz/...)
Step 5: Double-Click downloaded file.
Connect & Enjoy.
Thanks to Mud for the thread: https://forum.ih8mud.com/.../how-to-techstream-in-5.../...
"><img src=" /> ">
AMAZON.COM"><span style=AMAZON.COM" /> AMAZON.COM">AMAZON.COM
LZLRUN Mini Vci Interface for Toyota J2354 Tis Techstream Diagnostic Cable Toyota Firmware V1.4.1"><span style=LZLRUN Mini Vci Interface for Toyota J2354 Tis Techstream Diagnostic Cable Toyota Firmware V1.4.1" /> LZLRUN Mini Vci Interface for Toyota J2354 Tis Techstream Diagnostic Cable Toyota Firmware V1.4.1">LZLRUN Mini Vci Interface for Toyota J2354 Tis Techstream Diagnostic Cable Toyota Firmware V1.4.1
LZLRUN Mini VCI Car OBD II Diagnostic OBD2 Scanner to USB Port Scan "><span style=LZLRUN Mini VCI Car OBD II Diagnostic OBD2 Scanner to USB Port Scan " /> LZLRUN Mini VCI Car OBD II Diagnostic OBD2 Scanner to USB Port Scan ">LZLRUN Mini VCI Car OBD II Diagnostic OBD2 Scanner to USB Port Scan
I've got this running on my win10 ultrabook with no issues.
Old Oct 4, 2020 | 10:57 AM
Lexus4321's Avatar
Lexus4321
All those links are NG.
I have TS V15.00.026 software, just need the interface device, etc. Don't need virtual box , I will install right onto a Win10 laptop, etc.
Old Oct 4, 2020 | 06:29 PM
tz693's Avatar
tz693
"All those links are NG.
I have TS V15.00.026 software, just need the interface device, etc. Don't need virtual box , I will install right onto a Win10 laptop, etc."
Can you share the link and instruction?
Old Oct 15, 2020 | 08:00 PM
Lexus4321's Avatar
Lexus4321
Start HERE, sign up, follow their instructions.
I bought a Drew Mongoose Pro as I did not want to play around with hacked interface stuff, etc.
Old Oct 16, 2020 | 05:57 AM
Lexus4321's Avatar
Lexus4321
Just some FYI
1) When dealing with rar and iso files (various forms of compression & archives), use 7zip app
2) Download the FCIV tool from Microsoft
https://www.microsoft.com/en-us/down....aspx?id=11533
3) After getting this version of TS (which is signed using a Denso certificate), verify the hashes using the FCIV tool. I did download this TS version from a variety of places, I found the EXE having these hashes (for this version) appears to be legit.
TS v15.10.0.29 ("Techstream_Setup_V15.10.029.exe")
MD5 ba0224e749d3c10e7d3742568e73f64c
SHA1 f0bf69a7cac1a656f6a4dffabebe1c1d8a10b553
Old Oct 16, 2020 | 01:38 PM
tz693's Avatar
tz693
pleas check PM
zeeshan66
GX - 1st Gen (2003-2009)
Nov 16, 2016 09:00 AM
FrigginFGO
GX - 2nd Gen (2010-2023)
Nov 6, 2013 09:22 AM
kevin9812
Jul 6, 2010 02:23 PM
JWS3
Nov 13, 2005 02:35 AM
