Key Programming help! Dealer says I need a new ECU!
Old May 18, 2020 | 06:36 PM
alikaftw's Avatar
alikaftw
Default Key Programming help! Dealer says I need a new ECU!
I just bought a 2003 GX470, went to the dealer and bought a couple new keys (mine only came with a valet key). They tried to program them and came back saying that it can’t be done and that I need to buy a new ecu to do it. I don’t have the money for that right now but the thing is, while trying to program my new keys they did something to the GX and now the security light won’t stop flashing even with the valet key it came with. They never told me that this was a possible outcome, had I known that I would have never gone ahead with it. What can I do?
Old May 19, 2020 | 05:51 AM
campfire's Avatar
campfire
Sounds like he screwed up the programming sequence- esp if the security light wasn't flashing before. I have a key programmer and good instructions if you'd like to try dong it yourself. $25 shipped boxermachine at gmail dotcom
Old May 19, 2020 | 06:26 PM
chiph9's Avatar
chiph9
Try contacting a locksmith. Some of them are pretty good at programming cars. Ask them if they specialize in Toyota/Lexus.
Chip H.
Old May 19, 2020 | 09:48 PM
alikaftw's Avatar
alikaftw
is it a techstream?
Old May 20, 2020 | 07:25 AM
IanB2's Avatar
IanB2
Originally Posted by alikaftw
is it a techstream?
You can program keys with a techstream, but if what the dealer says is true and the ecu is fried, it's not something you'll be able to fix yourself easily.
I'd start by getting as many details as possible from the dealer about what the issue is and what the repair entails.
Old May 20, 2020 | 10:53 AM
alikaftw's Avatar
alikaftw
The way the whole thing went down was strange. I live on an island in Hawaii without a Lexus dealership, just a Toyota one. I went in asking about getting some keys and they said no problem we just have to order them from the neighbor island. They came in a week and I brought the GX in to get them programmed. I waited in the waiting room for three hours and then they told me they couldn’t do it and that I needed a new ecu to get new keys added, and that in the process of trying to add the new keys did something to the ecu that made the security light stay flashing even with my current key inserted and engine started. I asked them to reverse whatever they did and they said it can’t be done, I need a new ecu.
Old May 20, 2020 | 12:13 PM
IanB2's Avatar
IanB2
Almost sounds like they tried to erase the saved keys in the ecu (as there is a max number that can be saved) and cleared all keys rather than just the ones you no longer had, but weren't able to get the original key(s) added back in. I'd start by asking the dealership to provide a report on exactly what they did and what went wrong, and take it up with Toyota/Lexus corporate. If they broke something that should be a them problem, not a you problem. On the other hand, it's always possible this had nothing to do with the work they were doing, **** happens. You need more info as a starting point.
Old May 20, 2020 | 12:55 PM
swfla's Avatar
swfla
You may find this youtube video helpful or at least educational for your situation.
. youtube is a terrific source of info. Even if this video doesn't solve your issue, you're on the right path to resolution. Please keep us informed to your progress. Best wishes.
Old May 20, 2020 | 02:47 PM
Bovineplan's Avatar
Bovineplan
Amazon Amazon
I can't verify this will work for you but it worked for me. I had a valet only key but my security light was not flashing when I bought my 04 GX. As far as I know 03-04 is a bit of a pain to add new keys. The instructions were not quite correct for me but I figured it out in less than 30 minutes had two new keys and fobs programmed to my 04 GX.
For $18 plus the cost of keys/fobs it's worth a shot. I had a local key place cut the keys which was $25 per key. They referred me to a local key programmer which quoted $65/fob to finish the programming. I decided to give this a try and it worked.
Some of the reviews say it requires a master key. Others say it doesn't. I don't know the correct answer but I can tell you my aftermarket key worked just fine.
my thread which includes pics of my keys and such.
https://www.clublexus.com/forums/gx-1st-gen-2004-2009/931296-new-to-us-2004-gx470.html
Good luck on it.
Old May 20, 2020 | 08:25 PM
alikaftw's Avatar
alikaftw
After a lengthy heated phone call with the manager with home stonewalling me when asking for info or read outs, he said he was willing to give me a new ecu at half price. I didn’t agree with and after talking to the GM he ended up saying that they would give me the ecu at no cost but if I EVER needed keys programmed I would have to pay the full price of the ecu. I think it’s petty and he needed to feel like he “won”. After they put in a new ecu, will I be able to go through one of the DIY routes to add my keys?
Old May 20, 2020 | 09:01 PM
Bovineplan's Avatar
Bovineplan
As far as the new ecu, if you get a new ecu I think it has to be programmed. Meaning when you pick up the vehicle if it isn't programmed it won't start. I assume the dealer would do the initial program during ecu install. Otherwise they would have a vehicle that won't start. Other smarter GX owners maybe can chime in.
For me. I read the ecu horror stories. I bought the device I linked above and it worked for me.
Old May 21, 2020 | 12:36 AM
alikaftw's Avatar
alikaftw
Yes they are going to swap it out, free of charge with the stipulation that if I ever want another key added on, I have to pay the full price of the ecu.
Old May 21, 2020 | 07:57 AM
IanB2's Avatar
IanB2
I've added a new key myself with a pirated techstream and cable setup on my laptop. There's tutorials out there to walk you through the process, but if they are installing the new ECU and programming the 2 keys at that time, you shouldn't ever need to worry about it again if you look after those keys. Even if you break the key case, there are aftermarket key cases you can swap the guts and key shank into with no reprogramming necessary.
Good outcome!
Old May 21, 2020 | 08:31 AM
swfla's Avatar
swfla
Sorry that the dealership was so difficult. Bottom line, get the number of keys made that you need ( I suggest 2 ). Play nice and buy the keys from them if you need keys. Try to forget about the remote need for more keys and any fees that they threaten to charge. put your cell number on your keys in case you lose it. You'll likely never need any more keys. In time you'll feel better about the whole situation. Sounds like a resolution to me. Congrats for being determined.
Old May 21, 2020 | 10:26 AM
alikaftw's Avatar
alikaftw
They are only going to program the valet key I had before they worked on the car, and if I want any additional keys I have to pay for the ecu.
