E Brake and Brake hardware replacement tutorial/Video?
Need to change my brake shoes and would like to change all the springs and other contraptions in there. Have a brake hardware kit and there is like 30+ pieces. Is there a good solid video/walkthrough for the job?
This video is probably as good as they get for the rear brakes. But like the guy says, the hub assembly doesn't come off [1] so you can't see a lot.
[1] ..without disassembling the differential and releasing the clips inside it so the driveshaft can be slid out from the axle tube. And no one wants to do that for a brake job.
Chip H.
Chip H.
