Diagnosis Thread
Old Feb 16, 2019 | 01:23 PM
Tankfighta's Avatar
Tankfighta
Default Diagnosis Thread
I’ve got a 2009 GX with <86k on it. KDSS system, magnaflow catback exhaust
Check engine came on along with the VSC Trac, VSC OFF, and the swerving car symbol.
The car doesn’t drive any different than usual (aside from the VSC being off but I dont like that anyways)
There were a lot of codes but the tech at O’Reilly wrote down maybe half:
C1201
C1223
C1241
P0441
P0455
I replaced the gas cap already (yesterday).
ABS light isn’t on so I assume it isnt the wheel speed sensors?
The alternator is fine and so is the battery (its cold in Alaska so its going to show a low charge always)
I’d rather fix it myself than pay a bunch of money to get it done. Any ideas or tests?
Old Feb 17, 2019 | 07:37 AM
chiph9's Avatar
chiph9
C1201 - nonspecific, but usually relates to stability control being turned off because of an engine management problem.
C1223 - nonspecific, but sometimes is related to a wheel speed sensor or a bad brake switch. Check for crud built up on the tone ring on your wheel hubs.
C1241 - Low battery voltage. Might be part of the cause of the other codes. Change the battery, check the alternator output.
P0441 - Evap system. Often set by a loose gas cap
P0455 - Evap system. Often set by a loose gas cap
Since you've already changed the gas cap, recheck the codes after a week's worth of driving to confirm they went away.
You say the battery voltage is fine - I would get a battery blanket and maybe a heat pad for it and plug it in when you're parked at night.
Chip H.
Old Feb 19, 2019 | 12:34 AM
Tankfighta's Avatar
Tankfighta
Chip H.
The gas cap fix worked! So glad I dont have to crawl around in the snow and check the sensors... it happened Friday and stopped on Monday afternoon.
$15.99 for the part
mofoco
Nov 4, 2019 02:56 AM
farklspark
Nov 25, 2016 03:59 PM
Kermee
GX - 1st Gen (2003-2009)
Sep 13, 2016 03:56 AM
Tapoling
Mar 5, 2013 02:18 PM
brigoli
Jan 2, 2013 08:15 PM
