Another Master Cylinder Question?
Old Feb 7, 2019 | 11:28 AM
khoality's Avatar
khoality
Default Another Master Cylinder Question?
I honestly tried searching to no avail, maybe I was searching for the wrong thing? Got the infamous buzzing and warning lights of the BRAKE, ABS, VSC TRAC AND OFF. The reservoir was filled to the cap of brake fluid. I checked each bleed valve and the 2 rear didn't have any fluid come out when I opened the valves. I then unscrewed the brake lines and as you can see from the pic, the top line is bone dry while the bottom has some fluid. Does that mean the master cylinder is shot? Will a rebuild kit save me from a very expensive replacement? Is it possible the lines to the rear are clogged? Any input/ideas would be greatly appreciated, thanks!
luis15diaz
May 20, 2019 10:01 PM
xjaduhx
Sep 13, 2018 04:13 PM
foreste1
Sep 30, 2017 02:01 PM
lexus-is2
Jul 19, 2014 10:15 AM
