GX470 Rear Suspension bottoms out sometimes over speed bumps. Techstream IMG attach
Subscribe
Mar 1, 2026 | 06:31 PM
Please let me know with any update to fix it, I have the same problem. I was about to buy a new air bag form amazon
Amazon Amazon
I was reading old post and someone using this for few years ( over 70K miles ) with No problem
Thank you
Reply 0
Mar 2, 2026 | 08:30 AM
Quote: Please let me know with any update to fix it, I have the same problem. I was about to buy a new air bag form amazon
https://www.amazon.com/SCITOO-Suspen...s%2C255&sr=8-3
Thank you
That was me that used those airbags. I am now at 224K miles and the airbags are still working fine. Definitely getting my moneys worth out of them!
Reply 0
Mar 2, 2026 | 12:23 PM
I appreciate your feedback, does it change the ride comfort compare to OEM air bag ? Thank you
Reply 0
Mar 9, 2026 | 08:24 AM
I managed to pick up an Aisen HST027 ride height sensor recently from Amazon for $100. Just need to get the 029 and then I can go ahead and replace the old rusty (and probably damaged) ones. I'm hoping this will keep the airbags inflated just a bit more than they are now which should keep those bump stops from hitting so often!
I've no idea what to expect when I get down to it. Probably remove the spare tire for a little more space.
Afaik, it should just be plug and play.
Anyone else have experience with replacing these?
Reply 0
Mar 9, 2026 | 07:28 PM
Let’s face facts
Compression and airbags are gonna fail in 2000 era vehicles in 2026. Pick a spring conversion! I went with Arnott for 4 Runner , Prado and Gx470 and went with Bilstien 4600 shocks all around and haven’t regretted it! It’s cost effective and works great for standard lift. I had done the drive shaft upgrade before, which was pointless once the spring conversion was done. But at least I got new u joints , so that’s a wash! GX470’s are fantastic vehicles for larger drivers who don’t mind 18 mpg. A hell of a lot better than my big block RWD big block 60’s and 70’s cars that stranded me in the winter.
Reply 0
Mar 10, 2026 | 02:01 PM
No experience replacing height sensors. I know there's a procedure in the repair manual, but I suspect if you measure from the center of the wheel hub to the lip of the fender before then match it afterwards (and perhaps a little higher...) you should be good.
Chip H.
Reply 0
Subscribe
