LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Stiff and bouncy front shocks 1999 LX
Old 06-07-10, 08:43 AM
v12mac
v12mac's Avatar
Default Stiff and bouncy front shocks 1999 LX (FIXED!)
Stiff and bouncy front shocks.
Something wacky is going on, my front suspension is stiff and really bouncy in my 99 LX. Ride height works fine, and all suspension settings are about the same in the front. The rear will stiffen up with the switch put the front end feels like a lo-rider bouncing down the road.
Any ideas or good threads?
Last edited by v12mac; 07-19-10 at 06:48 AM. Reason: Fixed, project done, update title for archive
Old 06-07-10, 08:50 AM
v12mac
v12mac's Avatar
I found this post:
https://www.clublexus.com/forums/lx4...n-problem.html
Is there a way to check the Gas Chambers?
Old 06-07-10, 09:09 AM
v12mac
v12mac's Avatar
And this post on the flush:
https://www.clublexus.com/forums/lx4...-and-safe.html
Anything else?
Old 06-09-10, 06:17 AM
v12mac
v12mac's Avatar
Anyone? Bueller? Bueller?
Old 06-09-10, 08:08 AM
IXI187IXI
IXI187IXI's Avatar
i dont know much about the LX but if the front suspension feels bouncy, thats usually the first sign that your shocks are blown and need to be replaced
Old 06-10-10, 07:17 AM
v12mac
v12mac's Avatar
Originally Posted by electro992
Most likely your accumulators(globes) are flat and need to be replaced. Happens with age as the high pressure gas inside slowly leaks out and removes the damping ability. Be sure to get genuine Lexus replacements - avoid aftermarket!
Dang, I was holding out hope that the fluid change would fix it but this sounds like the globe is bad.
THEY WANT $635.00 EACH!!! Deep breath.....
Since I am most likely going to have to go that route is there an after market system that would be better for heavy loads?
Old 06-10-10, 07:49 AM
v12mac
v12mac's Avatar
I went over to http://activesuspensionsystems.com/ and found some good info in the Blog section
http://site.activesuspensionsystems.com/blog/
Old 06-11-10, 06:20 PM
v12mac
v12mac's Avatar
Alot of members over at ih8mud.com have had bad experiences with the aftermarket globes from B&B suspension. They're always claiming they have a new design, but everyone who tries them always ends up going back to OEM. Best bet would be to buy the Lexus parts online for cheaper and have the dealer install.
Dang, I thought I'd found a way to do this for 1/2 price.
How hard could it be to make an accumulator?
Why would you have the dealer install them? My truck hasn't seen the dealer in ages.
Old 06-15-10, 05:41 PM
v12mac
v12mac's Avatar
Anyone have a Lexus or Toyota part number so I can start shopping?
Old 06-17-10, 05:36 AM
v12mac
v12mac's Avatar
Has anyone swapped it all out for the non AHC Toyota gear? Or one of the stock height after market kits?
Old 06-24-10, 05:30 AM
v12mac
v12mac's Avatar
Well I spent some more time looking at options. With help from the I hate mud guys. What I found is that I can use accumulators off of a 2007 Land crusher, and I can order them online for around $430 each. Now I am getting closer. The plan is to run it this way for 4-5 more years and when the system dies l am going to rip it all out and put in something aftermarket.
Old 07-19-10, 06:45 AM
v12mac
v12mac's Avatar
Well the job is done thanks to everyone here and at IH8MUD
I’d say over all this was easier than I ever thought it would be. If you can change a brake caliper this should be no problem. (With the right tools…)
Here is what I did. I went down to NAPA and picked up a 36mm fan clutch wrench. It fit perfectly!
side view
They had this in stock in a larger set and broke it out for me. If anyone wants to use it just shoot me an e-mail at v12mac at yahoo dot com (you can decode that, trying to keep the spam down) and I’ll mail it out to you as long as you send it back.
Drained off the pressure and remove globe.
Didn’t have a turkey baster or syringe so I sucked out all the fluid I could get out of the system with this
The hose fit in the hole snug and I could squeeze out air and make a slight vacuum that would draw the fluid out. The hose only is in the top ¼ inch or so, that keeps me from squeezing any back out of the bottle.
Bleed out the system as much as I could. I really would have liked to have a 2nd can of fluid to really flush the system but the Toyota dealer only had 1 in stock. I’ll re-flush and bleed when I can get another fresh can. By the way I got the AHC fluid for 40 bucks at Lexus down from 70, and the accumulators from Toyota for 430 down from 636 at Lexus. Not too shabby.
Miller time!
12oz ain't worth open' boy.
Old 08-24-10, 09:12 PM
stingrayy
stingrayy's Avatar
Default Toyota part #?
I have a 2000 LX470. Went through several after market globes and still having problem with the front ones. What is the Toyota part #? How are they workin out for you so far?
Old 08-24-10, 09:14 PM
stingrayy
stingrayy's Avatar
I have a 2000 LX470. Went through several sets of after market globes and still having problems with the front.
What is the Toyota part #? How are they working out for you? Which website did you purchase the parts from?
Old 08-26-10, 06:51 AM
v12mac
v12mac's Avatar
I found the best price online then I called my local "toyota" dealer and asked him if he would match the price so I could keep the biz local. He was able to match the price, in fact his computer wouldn't let him sell them for $.01 less than the price I asked for. He was kinda shocked at how I came up with that number!
I had to go to Lexus for the AHC juice. They came way down on the price when I said I needed the Toyota price. They had it in stock and cheaper than toyota listed it.
I'll have to go look up the part number off the invoice. But from what I understand it is the same part on all Lex / ota' s
Quick Reply: Stiff and bouncy front shocks 1999 LX
