Help diagnose radio problems
Old Sep 4, 2018 | 08:26 PM
ls3some's Avatar
ls3some
Default Help diagnose radio problems
Hi 2004 gx with ML and navigation here. Lost sound so after checking all radio fuses I figured it was the infamous ml amp and had it sent off and repaired at hi tech electronics in California. Comes back plug it in and still no dice. Ordered a used identical junk yard radio (tape player part below the Nav screen) still nothing. What I notice is this: no sound on am fm tape, very little garbled static sound on CD Player. Searching for fm or am gets you nothing it just keeps on searching over and over like I was out in the middle of nowhere. Is there a radio antenna box or another radio amp or something? Where is it located? Navigation sound works fine No error codes in the diagnostic screen or under LAN menu. I'm getting angry now. Help
Luke
Old Sep 5, 2018 | 06:42 AM
mrblister's Avatar
mrblister
Luke
I have same year same equipment with Rear entertainment system. I find sometimes cant turn radio on try pressing radio button tried steering wheel buttons. No luck then I smacked the steering wheel right where the volume and mode button is and the radio came on. I believe I have a clock spring going bad. You might want to check that. I just leave radio on when I turn off ignition and it works when I re-start. It could be a coincidence but as long as it works I will leave it be.
Old Sep 5, 2018 | 08:37 PM
ls3some's Avatar
ls3some
Thanks my steering controls seem to be working (station mode horn cruise)
Old Sep 6, 2018 | 12:08 AM
mrblister's Avatar
mrblister
Default Radio control
you can also try and see if you can turn radio on and off from the voice command button on the right side of your steering wheel also try the volume control as well
Old Sep 10, 2018 | 06:42 PM
hawaz123's Avatar
hawaz123
Default 04 Gx470 no radio sound
Hello i am new here and i am in need of your help or anyone that could tell me about the problem that I am having with my gx....
all of the sudden sound stoped from the speakers radio is working i could switch to c/d , am/fm , caset but no sounds.
i bought an amplifier installed it still no sound . My uncle has a gx470 tried the amp on his car worked. What could be the problem. I would realy appreciate your help...
Email. Hawaz123@sbcglobal.net
Old Sep 10, 2018 | 08:10 PM
chiph9's Avatar
chiph9
Do you have the Mark Levinson option?
Chip H.
Old Sep 11, 2018 | 06:25 AM
hawaz123's Avatar
hawaz123
Yes i do have ml . And i checked the sound option where it showes treble mid and bass . I am narrowing my diag to stereo caset . Could that be the problem?
Old Sep 11, 2018 | 01:42 PM
chiph9's Avatar
chiph9
Check the audio diagnostics:
Old Sep 11, 2018 | 07:44 PM
hawaz123's Avatar
hawaz123
Ok I just got my sound fixed came out to be a caset player that had shorted out and burned amplifier too ... so i had to buy a stereo caset from wrecking yard for $160 and an amplifier for $50 from craigslist .......good and happy news for owners of gx470 and possible any lexus from 03-06 with mark levinson... listen all any kind of mark levinson would work it doesn’t again it doesn’t have to be the same part number today i have just proved it on my owen 04 gx470 I installed a mark levinson amplifier from an 02 sc430 that had a mark levinson so if your amp goes bad get any mark levinson from any lexus believe me and take my word it will work do not let them trick you. I thought nk this is a good news for all
Leom257
Dec 15, 2017 01:15 PM
smp
Jan 12, 2015 10:21 PM
gg2012
GX - 1st Gen (2003-2009)
Jan 5, 2015 06:42 AM
westrella1
Mar 9, 2009 02:46 PM
attack7
Jul 25, 2006 08:35 AM
