Installing XM satellite antenna
Hi all - just aquired a 2004 GX470, looking to add satellite radio. I've done a search and cannot seem to find a thread on installing a satellite radio antenna. Anyone have experience doing so? Curious about best way to route the wiring.
Well, I don't know if this is the best way. However, this is what we did. I mounted the cable under the windshield trim in the middle of the roof, all the way forward.
The actual Sirius antenna is touching the window trim above the RVM.
I tucked the cabe under the rubber seal making sure it fit back correctly.
We came down the drivers side window trim and used black silicone to hold it in place.
I drilled a small hole in the firewall and used a rubber grommet with silicone passed it through under the dash.
(trying to keep fumes out, seemed to work well).
Tucked and zip-tied as needed.
Some people just run it hidden outside the car and into the drivers side door.
I think it works too. I just wanted a cleaner install.
