P0356 Ignition Coil Error Code - Only in Reverse
Old Oct 11, 2016 | 03:30 PM
cggeo555's Avatar
cggeo555
Default P0356 Ignition Coil Error Code - Only in Reverse
Hey guys,
I've used the forum quite a bit but first time poster, love what you guys do. I have a problem with my 2007 gx470 that ONLY happens when I am in reverse. It's usually when I first start the car (although that's usually the only time I use reverse). The engine will start missing pretty bad but then it usually stops after maybe 20 seconds and especially if I just go ahead and back out. All the usually suspect dash lights come on and it throws the P0356 error code every time. Sometime this won't happen for several weeks with no problem, but sometimes like right now it does it every time I back up. I replaced the F ignition coil (3rd cylinder from front on passenger side) with a Lexus part from the dealer about 3 months ago but it didn't help. Spark plugs were replaced about 15,000 miles ago but I don't remember this coinciding. Anyone have a clue why this is only happening in reverse? Thanks in advance.
Old Oct 12, 2016 | 05:57 AM
chiph9's Avatar
chiph9
Did you check for rodent damage to the wiring?
Chip H.
Old Oct 17, 2016 | 05:39 PM
cggeo555's Avatar
cggeo555
Yes, the wire has no apparent damage. The wire is pretty short coming off of the ignition coil and then disappears in a very thick heat insulated bundle so I don't think it has been chewed. Thanks for the thought though, that happened to the wiring harness on my old Mercedes. Anyone else have any ideas?
Old Oct 18, 2016 | 08:31 AM
mann777's Avatar
mann777
You replaced the wrong cylinder Ignition coil. You need to chk the No#6 ignition coil with the igniter circuit. This issue you are having purely on the secondary winding which when applies on the plug. The resident transistor is not generating enuf voltage to the primary coil. Replace the one and see the difference. And also the one which you removed #3 OEM chk. Resistance values with No#1 and #8.
Also you need to chk the freeze frame data with the OBD scan tool II. And check the engine temp and fuel air ratio whether are they lean or rich.
Old Oct 24, 2016 | 11:28 AM
cggeo555's Avatar
cggeo555
Thanks mann777,
I was under the assumption that cylinder F is cylinder 6 in the firing order diagram below. I replaced number 6 on the diagram. Am I wrong in my assumptions? Thanks.
vmichelle
Apr 15, 2024 01:34 PM
RobBurgin
Dec 9, 2020 06:10 PM
kimsey
Dec 29, 2018 12:28 PM
diplomat1
Oct 1, 2016 09:49 PM
2gs300
Dec 13, 2014 07:30 AM
