Outside temp reading is wrong
Old Jun 9, 2015 | 06:42 AM
GXallday's Avatar
GXallday
Default Outside temp reading is wrong
The outside temp reading in my GX is not accurate, it's showing 70-75 when its 91 outside. What do I need to do? Just replace this sensor? http://www.rockauto.com/m/mobilecata...rttype=7000&ck
I'm thinking the ACDELCO at the bottom of list?
Old Jun 9, 2015 | 07:14 AM
mustangpro's Avatar
mustangpro
I would first remove the sensor, clean it thoroughly, clean the connections, put dielectric grease in the pigtail and reinstall. Consider where the sensor is located, constantly exposed to the elements and road grime, it's pretty abused. That fixed one on a Jeep ZJ I had a while back. Might save you some cash if it works.
Old Jun 9, 2015 | 08:45 AM
chiph9's Avatar
chiph9
I agree. Unplug it, clean it, inspect for corrosion, plug it back in.
Chip H.
Old Jun 9, 2015 | 11:25 AM
GXallday's Avatar
GXallday
Thanks I'll try that. Do you guys know where exactly it's located?
Old Jun 10, 2015 | 06:19 AM
mustangpro's Avatar
mustangpro
I think I saw it behind the front bumper, right below the fan, dead center.
Old Jun 10, 2015 | 07:27 PM
mustangpro's Avatar
mustangpro
I'm sorry, told you wrong. It's located dead center of the grill opening area between the aux fan and the horn assembly.
bryceis250
Jun 20, 2018 07:11 PM
flyboyplo
Jun 29, 2013 12:18 AM
lonbon
GX - 1st Gen (2003-2009)
Jul 9, 2011 02:45 PM
jboy
Jun 12, 2009 09:20 PM
TexusRx
RX - 1st Gen (1999-2003)
14
Feb 22, 2007 07:12 AM
