Ouside air temperature indicator
Old Mar 6, 2003 | 02:23 PM
w4rjd's Avatar
w4rjd
Default Ouside air temperature indicator
My outside air temperature indicator reads very strange. When I first start the car the indication is about 20 degrees less than the real outside air. After driving the car for an hour or so, the indication is about 8 to 10 higher than the outside air temperature. This plays havoc with the A/C system and fresh vs. recycled air.
Anyone else seen this??
Old Mar 6, 2003 | 03:39 PM
bluntguy's Avatar
bluntguy
I've noticed that when I start mine up, I might program my car for 73, it's 60 inside the car, and the AC is on, further freezing my butt off. After a few minutes it seems to correct itself. You're not the only one.
shawn
Old Mar 7, 2003 | 12:32 AM
hipcheck's Avatar
hipcheck
Exact same problem here, I'm getting it checked.
With mine, it registers around 15 degrees below the actual outdoor temp when the car sits under a parking ramp for a day. It never seems to recover. If I keep it in my garage where the temp is currently higher than outdoors, it's always fine. No problem going down in temp, the issue is going up.
If this is the worst of the issues, I'm happy!
Old Mar 8, 2003 | 07:23 AM
w4rjd's Avatar
w4rjd
Had the sensor changed yesterday. The service advisor is not sure this will cure anything, but it seems to workiing correctly.
Old Mar 15, 2003 | 07:17 AM
Kbach's Avatar
Kbach
Is the new sensor still working right? My wife says ours isn't working right and I may ask for it to be changed too.
Old Mar 15, 2003 | 07:18 AM
w4rjd's Avatar
w4rjd
The new sensor is working perfect. Took 5 minutes to replace and 30 minutes to wash the car.
Old Mar 17, 2003 | 05:22 AM
tella's Avatar
tella
Angry Temp Sensor is not working right
I realized that my sensor is about 20degrees off what it needs to be and I took the GX to alocal dealership where they checked the out. After about an hour they still could not fix the car and the sensor is still ~20 degrees off. Should I contact a different dealership? The also told me that it may take up to three weeks to obtain the sensor, which is quite strange.
Old Mar 17, 2003 | 05:47 AM
w4rjd's Avatar
w4rjd
The first attemp by the dealer was to reset the computer. For this they removed a fuse for 10 minutes, re installed it and reset the clock. That made no difference. Next was to order the sensor. It was ordered on a Tuesday and replaced on the following Thursday. Fixed the problem. I would ask them to 'just order the sensor'.
If they want to verify the failed senor, have them place the unit in a ice water bath and see what dash indicator reports. Should be 32 degrees plus or minus two.
Old Mar 25, 2003 | 07:58 AM
tella's Avatar
tella
Wink The new temp sensor helped
Just had the new temperature sensor installed and so far it works the way it sould. Hope this fixed the problem permanently.
Old Mar 25, 2003 | 11:22 AM
w4rjd's Avatar
w4rjd
It has worked fine for me since the change. Good luck.
CLUM
Oct 29, 2020 09:30 AM
lyoooha
Jan 7, 2015 09:51 PM
jmscott
Oct 17, 2010 10:02 PM
ancdmd
Aug 15, 2010 08:18 PM
jimbonuttz
RX - 1st Gen (1999-2003)
Feb 16, 2010 07:43 PM
