04 Gx470 Reverse Issue
Old Mar 16, 2014 | 02:40 PM
ShakMan's Avatar
ShakMan
Default 04 Gx470 Reverse Issue
For some reason when Gx470 is parked, it does not want to reverse when slipped into gear. I have to apply a some pressure on the gas pedal and than it moves with a loud thud like noise, I have noticed it when the Gx is parked for 24-36 hours.
We leave here in N-CAL and weather cant be an issue. Besides it always parked in the garage. Anybody else experience this?
Old Mar 16, 2014 | 05:25 PM
RCsGX's Avatar
RCsGX
Nope.
Something isn't right.....
Old Mar 16, 2014 | 07:05 PM
ExiledWolf84's Avatar
ExiledWolf84
So wait, once you put it into reverse, does it act like it is in neutral until you rev the engine up higher, then it violently "jerks" into gear and starts moving?
That is the classic sign that your transmission fluid is low, or there is some other issue as well. do you have any leaks?
Old Mar 17, 2014 | 06:49 AM
chiph9's Avatar
chiph9
Are you parked on a hill?
What happens if you apply the handbrake when parking? (apply handbrake, then shift into park)
Chip H.
Old Mar 17, 2014 | 08:22 AM
ShakMan's Avatar
ShakMan
Yes, thats exactly the behavior. I don't see any leaks (at least not that I can spot) and just went thru a 90K in Dec 2013. Its always parked in my garage and so I would have noticed oil drippings.
I am not parked on a hill also.
Old Mar 17, 2014 | 03:31 PM
Booyah's Avatar
Booyah
Could be just low--I would have that checked first for proper fill before going into anything else, cause its happening when its Cold, not warm correct?
Old Mar 17, 2014 | 05:37 PM
RCsGX's Avatar
RCsGX
Good time to have your trans fluid flushed.
jc12
GX - 1st Gen (2003-2009)
Jan 25, 2019 06:10 PM
abaitedcat
Dec 3, 2018 07:53 AM
4TehNguyen
Nov 2, 2014 07:41 AM
z0lt3c
Jul 17, 2012 12:04 PM
jafoo
May 23, 2012 03:18 PM
