ghost
Old Dec 22, 2013 | 06:56 AM
belair's Avatar
belair
Default ghost
my int lights go on and off going down the road, and my alarm goes off by itself when set. it is a 2004 gx 470 what gives the dash light says door ajar but none are.
Old Dec 22, 2013 | 09:39 AM
RCsGX's Avatar
RCsGX
Old Dec 22, 2013 | 10:41 AM
gxman1's Avatar
gxman1
I had a exact problem in another vehicle, it turned out to be switch look like a L shape and when it made contact while the doors were closed, it sends a signal all closed and door are FULLY locked and can be armed.
Apparently the swithch somehow was not getting depressed all the way, Instead of changing the switch I taped around it giving it more padding, so when the door is closed it will push the switch further.
Open each door including the cargo, and press the switch by hand and see if they are loose and light in the cabin comes and go.
Old Dec 22, 2013 | 04:26 PM
ExiledWolf84's Avatar
ExiledWolf84
The Door switches either need to be adjusted/cleaned, or replaced. They are pretty simple assemblies not too cost prohibitive. From what i understand the one that most commonly goes is the one of the rear hatch.
Old Dec 28, 2013 | 12:05 PM
belair's Avatar
belair
Default ghost
thanks, switch was worn out, replaced it prob solved! I knew i could count on you guys
ckinglee82
GX - 1st Gen (2003-2009)
Oct 7, 2018 09:38 AM
GXJeff
Oct 27, 2016 01:00 AM
GreatHim
35
Feb 8, 2015 04:20 PM
rleggs
17
Sep 17, 2006 12:31 PM
LexusPride
Jan 3, 2005 07:45 PM
