Towing light not working even after installing relays
Old Jun 24, 2013 | 05:56 AM
keemhonk's Avatar
keemhonk
Default Towing light not working even after installing relays
The car does not come with towing package. Bought and installed 3 relays; 2 under the hood, one in the back. I connected hard wired TOW READY 20137 to the trucks' wiring system, checked voltage, nothing. Checked relays under the hood and and the back by the rear light, I could hear the clicking from them. Do I need to connect under dash brake controller too in order the wiring to active the wiring system ? Any idea why this is happening
Old Oct 14, 2013 | 08:29 AM
zippymbr's Avatar
zippymbr
you need to test with the trailer hooked up as the ground is through the ball, or you can run a ground wire.
Old Oct 16, 2013 | 07:52 AM
keemhonk's Avatar
keemhonk
Thanks I will try that
johnlor23
Mar 23, 2018 08:28 AM
Cbb129
May 17, 2017 05:34 AM
kaahari
Mar 29, 2016 05:36 AM
macjac69
Aug 23, 2014 11:10 AM
