Audio system suddenly doesn't detect Changer
Old Apr 6, 2012 | 04:21 PM
Bati's Avatar
Bati
Default Audio system suddenly doesn't detect Changer
Hi All - I have a 2007 gx-470, and all of a sudden, I can't do anything with the 6 cd changer. Pressing the "Disc" button on the audio system doesn't bring up the changer interface any more, and I can't eject any of the cd's that are in there.
I called the dealer and his answer was "Probably need to replace the whole thing .. 900$ plus work" .. yea, whatever .. My question is - anyone know where I could buy the changer device at a normal price? Is there a good website that sell those? I tried ebay but wasn't too lucky there.
Old Apr 6, 2012 | 04:46 PM
RCsGX's Avatar
RCsGX
eBay would be your best bet. Try this site too, they will find parts from salvage yards across the US: http://www.car-part.com/
Old Apr 6, 2012 | 07:52 PM
mann777's Avatar
mann777
Talking
That is what the dealers would say, and they are rightly said as "Stealerships". Without Troubleshooting they come up with solution " Replace".
Anyways is your truck with Nav or without Nav. Hopefully we can come to know where the problem lies.
And search on this forum, lot of GX have similar problems and some have been sorted out, you get some solution from other members also.
I did have mine the similar problem and only replace the CD changer. That was after lot of discussion with the Service Manager, and to know the exact issue. Sometimes you have to be firm and things will fall in place, or change your dealer, maybe they would be better.
There is Exchange Program for 2007 GX470 for CD CD Skips/CD does NOT play/CD does NOT eject/CD will NOT accept. TSB - AU001-06.
Old Apr 7, 2012 | 06:24 PM
Bati's Avatar
Bati
Thanks Mann777 - I tried searching this forum, and actually found a thread where you show someone how to get to diagnostic mode. I did that and everything seems normal.
Yes, I have navigation. The problem is very odd - there's power going into the changer (lights on it are on), but there seems to be no connection between it and the audio system. Pressing on the Disc/AUX button does nothing. Pressing on the eject (on the changer) does nothing as well (although if i'm not mistaken, the eject/load buttons on the changer only worked after pressing that Disc/AUX button and entering the CD interface, but not sure about that).
I also got a bit adventurous and disarmed the glove compartment to see if some electric plug was disconnected or something, but it wasn't as easy as I thought. There were too many cables down there, and all seemed connected (what was naked to my eyes, at least).
When you say Service Manager, do you mean the Lexus Dealership Service? Maybe I should try a different dealership?
Old Apr 7, 2012 | 07:44 PM
z0lt3c's Avatar
z0lt3c
I removed my CD changer and replaced it w/ a grom IPOD adapter. I sold the old changer on ebay for $90 -- so if it comes down to that, you should be able to find an affordable option. Although, why you still want to use CDs, I'm not sure....
I traced out alot of the CD changer cabling before I pulled it. The changer harness plugs into the back of the headunit and extends to a coupler inside the glovebox. The CD Changer then has a short cable which plugs into this coupler. I would suggest tracing all these connections. A continuity test on each pin would rule out the wiring loom.
If an aftermarket adapter was ever installed in your vehicle, you may find a Y cable in the back of the headunit on the CD changer port. I found this cable to be problematic and bypassed it in my application.
Old Apr 10, 2012 | 10:32 AM
mann777's Avatar
mann777
Yes as Zolt mentions..just try doing a check on the harness of the system rear. And have all the port harness removed and re-inserted firmly. Before you remove, if you have a Air Spray duster, have that sprayed around and then started working. including the continuity check. And if in case still you problem persist, the CD tray is quite cheap, you could get from the dealer for $70 odd, i think these days. Yes you dealership service manager is what I meant, and you could change the dealer if you find they are not worth the service they give.
Old May 6, 2012 | 08:39 PM
RedLizard's Avatar
RedLizard
I have the exact same problem with my Levinson changer....lights up, but is unresponsive to any and all input from the head unit. Lexus dealer quoted me $2700 to replace.
I don't much care about playing CD's, but I would like to be able to update the navigation some day.
There isn't any way to update the GPS w/o a working CD changer is there?
Old May 6, 2012 | 08:50 PM
RCsGX's Avatar
RCsGX
Your navigation disc is under the passenger seat. Unless your navigation stopped working too I dont see how the CD changer in the glovebox effects your navigation.
Old May 6, 2012 | 08:53 PM
RedLizard's Avatar
RedLizard
My bad, I foolishly assumed they were interconnected. Thanks for the info. Nav is working great. Knock on wood.
Old May 23, 2012 | 09:21 PM
Bati's Avatar
Bati
So here's my experience so far - I took it to a guy that supposedly knew what he was doing. He took the changer out, told me the changing mechanism is probably broken and he needs 10 days to order and replace. After 10 days he says he didn't know that it was a DVD/CD changer (it has the DVD sign on it .. ok, that's why i said "supposedly"). Of course I took it from back from him and was sorry someone as idiot touched my car.
The second audio electrician that I went to told me that Lexus invests more money in making the harness Lexus-Only. Meaning its configured in such a way that I can't just plug in third party changer. I have no idea if that is a true statement - I just assumed it is since it was in his interest to sell me one of those changers.
So I'm back to square one. I'll go to Lexus and ask how much it'll cost to repair - probably more than 1000$. I just saw 3 of these on eBay for around 500$, used of course. I'm debating if to go that route ...
redtie
Dec 15, 2022 12:22 PM
GeneE
GX - 1st Gen (2003-2009)
Jul 17, 2011 03:48 PM
pismoj
RX - 3rd Gen (2010-2015)
Jun 29, 2011 02:22 PM
newbiegx
Jan 21, 2011 01:57 PM
ESDragon
Mar 16, 2007 09:11 AM
