Lumbar problem?
Old Sep 8, 2010 | 09:30 AM
ubond007's Avatar
ubond007
Default Lumbar problem?
Hey guys had a quick question...maybe a stupid one
I push the switch to add more lumbar support and it works fine. When playing with the switch to find the right settings i noticed that if i completely lower the lumbar and then try to add more support it does nothing. I have to wait a while before it starts to work again. any comments or suggestions?
Old Sep 8, 2010 | 09:54 AM
mann777's Avatar
mann777
Disconnect the battery and redo the whole stuff, as the ECM has some seat memory setting stored. Once the disconnect and reconnect happens, this will wipe the previous settings and then It will work fine.
Old Sep 8, 2010 | 10:14 AM
ubond007's Avatar
ubond007
mann777 by disconnect do you mean just the negative or both? will i lose my radio settings too?
Old Sep 8, 2010 | 10:37 AM
redrocks's Avatar
redrocks
One should do and yes, you will lose your radio settings and probably have to reinit the windows and sunroof.
Old Sep 8, 2010 | 09:35 PM
mann777's Avatar
mann777
Just the (-) terminal only. Wait for 3 mts, and then re-connect. You will lose the Clock, Radio , Doors Glass and other extra which run on memory setting. Just re-do them once. And then target the seat settings at the last. cheers
Old Sep 9, 2010 | 07:09 AM
ubond007's Avatar
ubond007
thx guys appreciate it!!
awdxtc
Apr 27, 2018 05:18 PM
elester
Jan 10, 2012 08:22 AM
austinmw
Dec 17, 2011 07:41 AM
Stevens226
Aug 31, 2008 02:04 AM
