Is this much rust normal for an 05 GX?
Old Oct 7, 2008 | 11:28 AM
mwbuck's Avatar
mwbuck
Default Is this much rust normal for an 05 GX?
Is this normal?
Old Oct 7, 2008 | 12:46 PM
The G Man's Avatar
The G Man
That doesnt look normal for a 4 year old car. Looks like that under carridge have been thru a lot.
Old Oct 7, 2008 | 11:47 PM
tightlinez's Avatar
tightlinez
err... no way
Old Oct 8, 2008 | 10:36 AM
tigmd99's Avatar
tigmd99
I guess that it snows in your neck of the woods...but do you live by the ocean also?
Old Oct 8, 2008 | 11:28 AM
LexusBob's Avatar
LexusBob
I have an '05 too, but not rust like that. Salt is the worst. If it snows alot around you and they salt alot, that could explain it.
Old Oct 8, 2008 | 02:30 PM
<VENOM>'s Avatar
<VENOM>
It's surface corrosion, when you can break a piece off then it's bad
Old Oct 8, 2008 | 03:01 PM
BurgBoxstr's Avatar
BurgBoxstr
greetings also from PA (the other wrong side though ) Anyhow, seeing as though it's mostly on the frontal wear portions and with all the s#it they spread here in winter, yes it looks pretty normal... er... it looks normal compared to my '04
Old Oct 10, 2008 | 07:14 PM
cazz1911's Avatar
cazz1911
Check warranty. I believe the GX has a "no rust" guarantee. Either way, when I detail my vehicle, I drive it up on ramps and rinse the undercarriage with a power washer.
Old Oct 11, 2008 | 05:48 AM
mwbuck's Avatar
mwbuck
I thought the No Rust Warranty only covered the paint on the car?
Old Oct 11, 2008 | 05:55 AM
tigmd99's Avatar
tigmd99
Rust warranty on most cars is for penetrating rust, not surface rust.
Old Oct 24, 2008 | 05:21 PM
super_cjc's Avatar
super_cjc
looks pretty normal to me.
Old Oct 24, 2008 | 05:25 PM
caha14's Avatar
caha14
My '04 looked almost like that in '05 after only one winter (albeit a very snowy one). It should all be surface rust and nothing to worry about, though upon initially discovering it back then, I did worry.
The undercarriage of the GX is "strong like bull" .
tecman
GX - 2nd Gen (2010-2023)
Feb 10, 2020 05:03 PM
petsb10
GX - 1st Gen (2003-2009)
Sep 28, 2005 05:43 AM
Fusion400
May 29, 2005 10:01 AM
