Turn Signal Bulb Replacement
Old Aug 26, 2008 | 01:49 PM
Megafast13's Avatar
Megafast13
Arrow Turn Signal Bulb Replacement
I just picked up the bulb, but how do you replace the Right turn signal on a 2003 Gx! thanks
Old Aug 26, 2008 | 02:27 PM
BurgBoxstr's Avatar
BurgBoxstr
I haven't personally changed mine, but I did put in the XD HID conversion kit. Anyhow, to access the back of the housing to change the headlights, just pull the plastic liner under the hood/behind the grill (7-10 plastic clip/retainers which pull right up plus 2 extra ones on the passenger side connecting it to the plastic cover that leads up to the firewall). Once the retainers and shield are out, you'll have access to the back of the light housing. From there, you'll be able to tell which bulb is which. Unless you 'know' you make 3-4 times more right turns than left.... you should replace the same bulb on the opposite side or you'll most likely get to repeat pulling the liner in short order Gets a little tight on the driver's side due to the battery but you've got a ballroom on the passenger side.... Good luck
Old Aug 26, 2008 | 07:38 PM
brickauto's Avatar
brickauto
The Search function is your friend
Old Aug 27, 2008 | 05:58 AM
mkupchyk's Avatar
mkupchyk
That thread says that you get to it from the ground under the front bumper. Someone else said they have done it from the top under the hood. So looks like both ways are possible. My suspision is that doing it from the top requires small hands and is a tight squeeze, so from under the bumper may be easier.
Now thats obviously for the front signal.
Were you talking about the rear? If so it may be the same process, but I think that someone said you can get to it from inside the truck.
cgabb1
GX - 1st Gen (2003-2009)
Jan 25, 2024 06:38 AM
zippinbye
Nov 23, 2020 03:41 PM
spxChrome
45
Jan 6, 2015 03:25 PM
Red Green
Sep 12, 2010 12:05 PM
98ls400
Aug 16, 2001 05:49 PM
