GX Alternator
Old Jul 7, 2008 | 12:41 PM
LexGX's Avatar
LexGX
Default GX Alternator
Does anyone know the amp output on our alternators?
Old Jul 7, 2008 | 01:30 PM
tigmd99's Avatar
tigmd99
That info can be found at the end of your Owner's Manual under specs.
EDIT: From Googling, it seems that GX470 alternator has an output of 130 amps.
Old Jul 7, 2008 | 01:47 PM
LexGX's Avatar
LexGX
I never thought about looking at the owner's manual but thanks!!! Reason i ask is because i have an audio system in my gx and i just wanted to know some specs of the alt. Now i need to go google about the factory battery.
Thai, what are your thoughts on this?
Old Jul 7, 2008 | 07:38 PM
tigmd99's Avatar
tigmd99
Most stock alternator/battery is good enough for most aftermarket audio equipment as long as you don't go crazy and add 12 amps and 12 subwoofers! Remember, your stock Mark Levinson amp is probably aftermarket quality in terms of it's draining power. If you have just two aftermarket amps (one for woofer and tweets and one for sub), then you should be good to go. Or if you're just adding a sub + amp, then i think that you're OK.
Have you done much to your audio system since we last spoke??
Old Jul 7, 2008 | 07:50 PM
LexGX's Avatar
LexGX
I have not but this time i was messing around some more at night time. This was when i notice that my lights were slightly dimming and so i'll be doing the big 3 soon to see if it helps out any. If it doesn't then i'll be buying a 2nd battery, that i know should stop the dimming. When i go back to Auburn this fall, i'm going to upgrade my system to 2 12" re se with a pa3000d amp so i know dif. then i will have to get bigger wires and a 2nd battery for sure. I just never notice the dimming until last night.
Kane007
May 18, 2015 08:16 PM
IC350
Nov 2, 2014 07:54 PM
gdave
May 5, 2008 06:21 PM
mick_foley
Oct 21, 2007 12:37 AM
2Tone93
Sep 19, 2006 04:32 PM
