2 Quick Questions
Old Feb 28, 2007 | 06:03 AM
Yaron2's Avatar
Yaron2
Default 2 Quick Questions
2006 GX470
1) Is there a way to automatically turn the rear AC on when you turn on the front AC? Also is there a shield I can buy to cover the rear controls to prevent my kidsfrom kicking it which turns it on and off??
2) How can I use the NAV while driving? Currently the touchscreen will not work while the car is moving. While I understand the safety feature .... it is annoying and I would like to bypass it.
Thanks in advance!!
Old Feb 28, 2007 | 09:16 AM
jjbodean's Avatar
jjbodean
CL Folding 25,000
Thanks in advance!!
search the forum, there are plenty of threads that discuss this, look for "navigation hack"
Old Feb 28, 2007 | 10:33 AM
V8_Fan's Avatar
V8_Fan
2006 GX470
Thanks in advance!!
1) Doesn't the rear A/C button stay "on" once you press it, even if you shut off the engine? It does on the LX.
2) Yes, you can, but be careful to hit *exactly* the correct buttons, otherwise a lexus tech (lexusBen) on mud said you can accidentally lock-up the nav ECU and the only fix is to replace it. And that's not covered under warranty since they know the only way to lock it up it to mess with the hidden menus!
Janiecr1
GX - 1st Gen (2003-2009)
Mar 20, 2017 07:36 PM
Fla904
May 4, 2016 12:47 PM
Nauticalx
Aug 21, 2009 12:43 AM
SGMIS3
Sep 24, 2006 07:57 AM
taejin09
Aug 9, 2006 09:33 AM
