Diagnostics Mode
Old Jul 28, 2005 | 06:16 PM
wld's Avatar
wld
Default Diagnostics Mode
Hello All,
Wondering if anyone knows how to get into the diagnostics mode on a '04 GX?
Old Jul 28, 2005 | 09:14 PM
greasemnky's Avatar
greasemnky
diag mode for what
Old Jul 28, 2005 | 09:16 PM
greasemnky's Avatar
greasemnky
for pretty much anything you need a scan tool which hooks up through the obd connector under th drver's dash area
Old Jul 29, 2005 | 05:21 AM
jdepiro's Avatar
jdepiro
Default Diagnostic Mode
Try this:
This is how you enable diagnostic mode, just turn off the car to get out of this mode
-Start car, turn on parking light
-Hold down both Climate and Audio buttons at the sametime do the next step
-Turn OFF parking light, then ON, then OFF, then ON, then OFF
You should see the service menu. Good Luck.
Old Jul 29, 2005 | 05:54 AM
lexusdr's Avatar
lexusdr
How in the hang did you figure this out. LOL
My Webpage
Old Jul 29, 2005 | 06:05 AM
jdepiro's Avatar
jdepiro
Default Diag Menu
It was in another thread a while ago. I tried it and it works on the Rx470. It does not however give you the same menu functions that enable you to override anything. You can just go through some diagnostics.
Old Jul 29, 2005 | 08:53 AM
Joel888's Avatar
Joel888
Default Great, but....
What sorts of things can you diagnose in this menu???
Old Jul 31, 2005 | 08:29 PM
yaro1's Avatar
yaro1
That's how I figured out I need a new head unit!
It can tell you if something is wrong with the Audio Head Unit, Amp, the backup camera, and a lot more. It is also a way to watch the backup camera while driving forward as if to watch a trailer in tow.
Old Aug 1, 2005 | 08:13 AM
Joel888's Avatar
Joel888
I see, thanks Yaro.
Old Aug 1, 2005 | 09:53 AM
stl2chi's Avatar
stl2chi
does this work in the 2005? Watching the backup camera while driving would be very helpful
Old Sep 2, 2005 | 06:40 AM
4everlexus's Avatar
4everlexus
Default Diag Mode: Camera question
Yaro1,
I tried this a couple of times and was unable to see the camera image when in this mode. Do you have to do something special?
Thanks!
Old Sep 2, 2005 | 08:12 AM
yaro1's Avatar
yaro1
On my '04 GX it works. However, on my father's '05 RX all I see is gray when I go into RV cam Diag mode.
I think it might have to do with the generation of nav. Since the '05 GX and '05 RX have relatively the same nav, then if your GX is '05 that might be the cause. I didn't work much to figure out how to get it to work on '05 though. Is yours '05?
(EDIT: I checked your profile, yep it is an '05. Thats the cause then. I don't know how to work it ('05) yet though. Sorry.)
Old Sep 2, 2005 | 08:24 AM
yaro1's Avatar
yaro1
BY THE WAY:
A simpler way to get into the diag mode is this:
A. From almost any screen, press the "Display" button. A new frame pops up with settings.
B. Touch the top-left of the screen just below the frame, bottom left just above the frame. (repeat B two more times) Check out my stinky text-drawing interpretation below.
THE END
IE.
If this is the screen and the extra lines in the middle represent the framing, you would press where the numbers are in that order (except always touch where he numeber 1 is and 2 is, don't press out further to the right how it is show[ALWAYS STAY IN THE CORNER]).
_____________________________________
|135
|246__________________________________
|______________________________________
LexusLuvrz
GX - 2nd Gen (2010-2023)
65
Aug 16, 2021 08:14 AM
fscalulcci
RX - 3rd Gen (2010-2015)
Oct 28, 2018 04:18 PM
E12ic46
Hybrid Technology
Aug 6, 2010 06:19 AM
BananaGS
29
Apr 4, 2004 02:21 PM
