rear door lock problems.
Old May 15, 2005 | 06:28 PM
Rx900's Avatar
Rx900
Default rear door lock problems.
i remember someone here had this problem before, but i'm now having problems with my rear door lock. at times, the lock would jam, leaving it in the lock position even after pressing the unlock button (on the remote and inside). so i figured, maybe it just got stuck a little or something, so for a few days, if i had the problem, i would just lock, unlock, lock, unlock, lock, unlock from the switch and it would openm. today, i couldn't get the door open at all!!
anyone else had this problem and if so, what did the dealer do to fix it (meaning, did they do a lot of dismantling of the plastics inside)??
Old May 16, 2005 | 05:41 AM
CdeFabio's Avatar
CdeFabio
If you mean the rear hatch door, then there is a TSB for the lock assembly. Just take it to dealer and have them replace it. They replaced mine because my rear door was squeeking and when they looked at it they said there was a TSB for the door handle/lock assembly and just replaced it. Fixed the squeek and did not mess up any of the trim on the inside. Hope this helps!
Old May 16, 2005 | 10:49 AM
Tony's Avatar
Tony
Default I had that problem also
There is a TSB on that issue where the locking mechanism would stay in the locked position. It happened twice and the dealership replaced the entire door handle assembly without questions.
Old May 18, 2005 | 05:11 PM
Rx900's Avatar
Rx900
mine was the locking mechanism inside. they even said they had an updated one! so i'm guessin they're having quite a few busted door locks on some GX470s......
but it's all good now. good thing they didn't leave any scratches on the sidings. still have to check out for rattles (cuz it's really hot, so the plastics are expanded and the only was to tell for rattles is to drive it in cooler weather in which the plastics won't expand)
pernjiepoi
Apr 23, 2022 07:23 PM
jonathanrn
RX - 1st Gen (1999-2003)
Jan 30, 2018 11:01 AM
Nickv
Jun 6, 2013 04:48 PM
STONER
Jan 16, 2006 10:10 AM
The G Man
GX - 1st Gen (2003-2009)
Oct 13, 2005 07:31 AM
