Dealer Programmable Options ?
Old Apr 21, 2004 | 06:23 AM
El_Mono's Avatar
El_Mono
Default Dealer Programmable Options ?
For my BMW I was able to find a pdf file that showed what options where able to be programmed by the dealer. (For example beeps when unlocking, or only having to press the key fob once to get all doors to unlock.) I know that the owners manual vaguely discusses each option with an asterisk by it, but its a pain in the *** to look through it, especially if there is a pdf file floating around. Any infor anyone can provide would be greatly appreciated.
Old Apr 21, 2004 | 06:29 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
What you're looking for is called C-Best or Cbest options. I did a search and didn't find any posted here for the GX, but the thread below gives a possible solution.
https://www.clublexus.com/forums/sho...ighlight=cbest
We've got 'em for other models, want to see what the look like? Should in general be the same for the GX.
You may not have appropriate security to download this - try it though.
https://www.clublexus.com/index.php/...1/ss008l01.pdf
Old Apr 21, 2004 | 06:50 AM
El_Mono's Avatar
El_Mono
It downloaded .. thanks.
I called the local dealership and they are faxing me a copy as well. I wonder which ones will be the same.
Old Apr 21, 2004 | 08:17 AM
lyxxsx1's Avatar
lyxxsx1
Folks,
This is what I received after calling the Lexus Customer Care.
Thanks,
File Type: doc
Old Apr 21, 2004 | 01:52 PM
LEXUS4NZ's Avatar
LEXUS4NZ
Thanks lyxxsx1for the doc. I'd like to get the headlight delay reprogrammed at my 5000k service. Anybody know if the dealer will charge anything for the reprogramming?
Old Apr 21, 2004 | 03:00 PM
Kash's Avatar
Kash
cbest options are free, they better not charge u
Old Apr 30, 2004 | 12:06 PM
Terry34's Avatar
Terry34
My dealer--Pohanka Lexus in Chantilly,Va. wanted to charge me $100 to reprogram ONE c-best setting on my LS430 one month after I bought it. I complained long enough that the dealership finally did me a "special favor" and reprogramed it for free. Since their service isn't very good anyway I'll go elsewhere for my service and buying my next car but I think the best way to get reprograming free is to get it approved before you actually buy the car. Its what I'll do next year when I buy a GX470.
Old Apr 30, 2004 | 05:49 PM
brent0226's Avatar
brent0226
Some of those options I have changed without going to the dealer. I found this on a thread one day (I can't remember who posted it, so sorry if you did). Here are how to change the door lock settings:
______
Got this fron the dealer the other day. You can set the following auto door locking and unlocking functions. All times must be EXACT or it will not work.
(a) Locking linked with the shift position
All the dooor are locked automatically when the selector lever is moved out of the "P" position with the ignition switch in the "ON" position. This is suppose to be the default setting for new vehicles.
(b) Unlocking linked with the shift position
All the door are unlocked automatically when the selector lever is moved to the "P" position with the switch in the "ON" position.
(c) Locking linked with the vehicle speed
All the doors are automatically locked when the vehicle speed reached 12 mph or higher. However, if any door is unlocked during driving, the auto function will not operate until the unlocked door is opened once.
(d) All the doors are unlocked automatically when the driver's door is opened within 10 seconds after the ignition switch is turned from "ON" to the "ACC" or "LOCK" position.
Setting the functions
1. Close all the doors.
2. Turn the ignition switch to the "ON" position.
3. Within 10 seconds after the ignition switch is turned to the "ON" position;
+To set function (a)
Push and hold the front of the power door lock switch for 5 seconds with the selector lever in the "P" position.
+To set function (b)
Push and hold the rear of the power door lock switch for 5 seconds with the selector switch in the "P" position.
+To set fuction (c)
Push and hold the front of the power door lock switch for 5 seconds with the selector switch in any position except "P".
+To set function (d)
Push and hold the rear of the power door lock switch for 5 seconds with the selector switch in any position except "P".
All the doors are automatically locked and unlocked when you release the power door lock switch. This indicates that the functions is set. If all the doors do not lock and unlock, the time the switch was held may have been too short or too long. Perform the procedure over again starting at step 1.
If you want to cancel a function, repeat the procedure. Each time you perform the procedure, the function is set or cancelled.
Old May 1, 2004 | 09:10 AM
Kash's Avatar
Kash
CBEST options are allways free to reprogram.. if not call 1-800 customer care and complain
Old May 2, 2004 | 04:22 AM
Terry34's Avatar
Terry34
I did call the 800 number and Lexus said it is up to the dealer. Lexus was no help on this issue.
Old May 5, 2004 | 06:27 AM
177mph's Avatar
177mph
The files listed above are not for the GX. Does anyone have the GX files?
RyanofCA
GX - 1st Gen (2003-2009)
28
Oct 6, 2021 12:23 PM
HaywardLex
Oct 9, 2016 07:01 AM
chicho55
Feb 5, 2013 08:56 AM
I6turbo
Nov 14, 2006 05:55 AM
177mph
Feb 1, 2003 10:03 AM
