View Poll Results: Has anyone had running board problems on GX470
Yes
31.58%
No
13
68.42%
Voters: 19. You may not vote on this poll
Running Board Defect
Old Feb 28, 2004 | 08:27 PM
GX470VA's Avatar
GX470VA
Default Running Board Defect
Has anyone had problems with the pins in the back of the running boards popping out when you stand on them.
The quality of the running board mounting seems to be problematic.
Old Feb 28, 2004 | 09:54 PM
tetra7's Avatar
tetra7
same thing happened to me...have them readjust the board...quick easy fix..if you need more help pm me and ill send you my advisors name and the fix..no biggie
Old Feb 28, 2004 | 09:56 PM
Tony's Avatar
Tony
Default Mine did that
My pins popped out the day I took delivery right in front of the sales guy. He took the truck to the service department and they did something and that was the last time it happened so far.
Old Feb 29, 2004 | 04:44 PM
looknow12's Avatar
looknow12
I've not noticed any problems.
Old Mar 1, 2004 | 12:39 AM
Capirato's Avatar
Capirato
Default Re: Mine did that
They replaced two buttons, but know darn well they will also pop out again.
Old Mar 1, 2004 | 06:35 AM
Traturn's Avatar
Traturn
I have seen many GX's with these clips falling out. Usualy just the rear 2 clips.
It appears that any weight on the rear of the board is supported by these clips, which is a horrible design.
Old Mar 1, 2004 | 08:36 PM
Kash's Avatar
Kash
my 03 did not have this problem as i used to get on teh verry back to clean the top of the gx
Old Mar 3, 2004 | 09:24 AM
kph3's Avatar
kph3
Same problem with mine. Replaced the right two missing and the left two missing last week.
Old Mar 8, 2004 | 07:48 AM
geewiss's Avatar
geewiss
Had the same problem with my 03 GX. They replaced the clips with what they called "stronger ones" and it has not happened again.
Old Mar 10, 2004 | 06:09 AM
lexite's Avatar
lexite
Two pins off of left rear within 2 weeks of my 2003 GX. Since then its fine.
brent0226
GX - 1st Gen (2003-2009)
12
Jan 23, 2004 12:27 PM
GlobeCLK
Mar 9, 2002 04:56 PM
Lex Luthor
Feb 10, 2002 11:15 PM
Richie
Jan 29, 2002 02:08 PM
