Help needed on air suspension; adding back or what?
I'll preface my question with I took a look in the following thread:
Air Suspension Problems or Questions - Page 23 - ClubLexus - Lexus Forum Discussion
I didn't find exactly what I was looking for. So I'm hoping can help me out.
I am unhappy with the ride height. Under the frame is ~14" and the rear wheel opening is ~8". Here is handy picture showing wheel well gap:
If we use this picture from the above thread:
I would like my ride height to look more like the low position and not what appears to be a 2" lift. So my question is quite simple:
How do I accomplish this?
Every shop that deals in GX470s that I've contacted have been no help on zero or negative lift coils. Is there a known 1" drop spring for front/rear?
If not, are there any quality airline replacements(braided)? Mine didn't look in great shape nor complete. And if I'm buying replacements, I'd rather go a sturdier replacement.
From reading various threads, the impression I got is OEM is only way to go for air parts. Was that still the case? Yes, I realize I'll spend a small fortune but I'll do it to get look/use I want.
Here is a chop of a picture I had handy. I will see about getting a better picture that includes the front when I'm not burning up
Based upon your picture, it feels like I've got a two inch lift spring. I put the red line to follow the door line. In your picture, it looks like ~2" of tire above the line while mine looks almost matched.
That 2" also lines up with the feeling that most air bag replacement kits do 2" lift. So it looks like I need to find a stock(zero lift) spring set or even a one inch drop set. Yes, dropping 1" over stock sounds odd but here is one of my wheelers:
Just a mildly build FJ55 on 35s.
There's some rake stock, and you need to bring the rear up about 1" to level.
So far as going back to air springs - I think the main reason would be because you tow and want the auto-leveling (no more squat).
What to order will depend on what they removed when doing the steel conversion. Hopefully the air lines, compressor, etc. are still there and they just pulled the fuse after removing the bags
Chip H.
Chip H.
