Cylinder 1 misfire error
Old May 11, 2026 | 08:48 AM
ArthurM's Avatar
ArthurM
1st Gear
Cool Cylinder 1 misfire error
My Lexus GX470 is currently showing a cylinder 1 misfire error, but only during engine startup. I have already replaced the spark plugs and the ignition coil, however the problem still remains.
There is also another issue: the coolant/antifreeze level keeps dropping and needs to be topped up regularly — approximately 0.5 to 1 liter per week.
I was told that the left cylinder head may be cracked and needs to be replaced. According to the diagnosis, coolant from the cooling system may be leaking into the combustion chamber. As a result, when the engine is still cold, the air-fuel mixture in cylinder 1 does not ignite properly, even if the ignition system is producing a spark.
I would like to know whether anyone has experienced a similar problem with the GX470, and what the actual solution was.
Old May 11, 2026 | 01:59 PM
chiph9's Avatar
chiph9
Loss of coolant with a misfire is normally pretty serious.
I would pull the spark plug and use a camera to see if there's any scoring on the cylinder walls, and whether the top of the piston is being washed clean.
Also do a cooling system pressure test.
Chip H.
Old May 20, 2026 | 05:04 PM
11bravo's Avatar
11bravo
What year and how many miles, please....
Old May 22, 2026 | 08:41 AM
IanB2's Avatar
IanB2
You could check the oil for signs of coolant (inside the oil fill cap often gets white crud built up if this is the case), and do a compression and leakdown test on the suspect cylinder.
Coolant doesn't just disappear, so if you don't have an external leak, you likely have an internal leak, and I would treat that as very serious, in need of attention. .5-1L/week is a serious leak.
Taimoorali08
Feb 8, 2024 11:30 AM
ccconor
14
Nov 29, 2022 02:51 PM
Rx3502009
Nov 21, 2022 07:31 PM
jonnyz2
May 23, 2019 08:53 AM
Eric00GS3
Sep 14, 2007 08:17 AM
