ABS code C0236 & C1223
Old May 10, 2026 | 05:34 PM
lstommy's Avatar
lstommy
10th Gear
Default ABS code C0236 & C1223
[img alt="2003 GX 470
Went on a roadtrip, abs, brake light went on, pulled the code and saw these 2 codes.
Restarted the car and lights are gone but code is stored.
No brake issues or noises from the abs pump.
Any ideas on what i should check?"]https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_5418_5be3f3369716500a5da43053cfc04eeca95117a2.jpeg[/img]
2003 GX 470 Went on a roadtrip, abs, brake light went on, pulled the code and saw these 2 codes. Restarted the car and lights are gone but code is stored. No brake issues or noises from the abs pump. Any ideas on what i should check?
C1223 and C0236
Old May 11, 2026 | 01:57 PM
chiph9's Avatar
chiph9
C0236 points towards a rear wheel speed sensor. I expect the C1223 is a follow-on code to that.
I don't see a reference as to which speed sensor (left/right) C0236 is, so check them both, and check the wiring.
Chip H.
SENSAY813
Jun 7, 2026 10:07 PM
SWH113
May 15, 2024 02:05 PM
bryceis250
Dec 31, 2019 07:05 PM
khalid9620
Jan 15, 2016 08:02 AM
mhmh
Oct 26, 2012 01:03 PM
