Fog Light Switch
Old Sep 1, 2012 | 11:51 PM
818GS's Avatar
818GS
Default Fog Light Switch
My fog light switch is loose. It turns on but when I use the blinkers and I turn and it goes back to its place it moves the switch and turns it off. Is something out of place in the switch that I can fix or do I need a new switch. If I need a new switch where can I get one for a good price and how hard is it to install. Thanks for the help.
Old Sep 2, 2012 | 12:51 AM
1sWt2GS's Avatar
1sWt2GS
bananna gs had the original fog light mod is thats what you were talking about
careful with using thin wires, ive seen a few threads here where the pins and wires melted.
new switches can be found at junk yards
Old Sep 2, 2012 | 01:39 AM
818GS's Avatar
818GS
No, its just that the switch to turn the fog lights on is loose. It won't stay in place so the slightest tap can turn off the fogs. I just wanted to know if that was a problem that could be fix or if I would need a whole new switch.
Old Sep 19, 2012 | 08:39 AM
LudeNsoL's Avatar
LudeNsoL
Any luck? I have the same problem.
Old Sep 19, 2012 | 09:00 AM
nyc80rick's Avatar
nyc80rick
I have the same problem believe its just the switch going bad. When ever I use my turn signal I just make sure to hit the stalk and not the actual fog part. Just seems like its worn out. If yours is shutting off even if your finger isn't actually touching it then you might need a new switch.
Old Sep 19, 2012 | 10:53 AM
jriggs's Avatar
jriggs
you'll need to replace the stalk, the parts are not available separate
Old Sep 19, 2012 | 11:06 AM
ThomasGS4's Avatar
ThomasGS4
I have this problem every now and then. I just put my finger on the end of the stalk and gently push towards the steering column.
Old Sep 19, 2012 | 10:09 PM
SorrGwa's Avatar
SorrGwa
Old Sep 20, 2012 | 12:16 AM
818GS's Avatar
818GS
Wow $100. Does anyone know how much install should cost?
Old Sep 20, 2012 | 02:22 AM
lextout's Avatar
lextout
new switches can be found at the dealer,used can be found at the junk yard but it probably has the same issue. My switch is the same way, it seems that this is a problematic part on some 2nd gen gs's
drkandre
Dec 30, 2012 12:38 PM
LudeNsoL
May 23, 2012 10:10 AM
ihiryu
Apr 15, 2012 09:42 PM
KahnBB6
Oct 21, 2011 01:48 AM
BAY HUSTLE
Feb 3, 2010 07:11 PM
