Square Setup
Recently got an awesome set of 19x10 RCF square wheels from @theman . Debating between staggering the tires, or running square tires also --
Few RC-F owners claim they even run 275/35/19 square, for track use on stock square wheels and stock ride height. Not sure how that would translate to full lock city driving.
Car is primarily for daily driving, I don't track. I don't care for thread comments on min/maxing center of gravity, roll center, wheel base increase causing steering response loss/gain. All of those things don't matter to much to me on a car that drives the speed limit on the highway, 99% of the time. Curb protection, pothole protection from tire height, and overall ability to rotate 4 wheels on a square setup are appealing to me.
- 265/35/19 front / 285/35/19 rear (+1 size up which is common)
- 295/30/19 all around square, not sure how the front would fit given it's a 19x10 wheel in the front with 26" of rubber diameter.
- 275/30/19 front / 295/30/19
- 285/30/19 square (highest you can get for all seasons could also be an option)
skipetenj Got away with it but this is possibly due to the 19x9.5 +43 wheel. Compared to the 19x10 +41 wheel i'd be running in front. I believe 265/35/19 might be as tall as it can go before it starts rubbing into the mud guard on city full lock driving.
265/35/19 front and 275/35/19 rear would be my choice. A 285/35/19 rear is pretty tall at 27 inches. I'm not sure how that would look since the 275/35/19 is already pretty tall at 26.6.
295/30/19 on a 10 inch wheel won't do you any good. A 295 needs a 10.5 or 11 inch wide wheel to make the most of that width.
Steve
Steve
Not all 295s are created equal. For instance a Toyo R888R has an 11.3 inch wide treadwidth while a Hankook Ventus has a 10.5 inch wide tread width. That Ventus may be fine on a 10 inch rim but a 10 inch rim with the R888R would be undersized.
Steve
Steve
