GS-F with 275/30 & 305/30 19 inch Titan T-S5
Hi guys,
Installed these today, just a FYI for anyone interested in a similar setup. I am on stock height/stock camber settings and have 0 rubbing front or back. The rear is a bit tight but no rubbing since I am on a 30 series tire.
These tires are the closest to OEM diameter that I can find while going as wide as possible. These are NOT the 19 inch hub centric specific application for GSF/RCF that came out recently as they have a much more aggressive offset which may not fit my tire setup.
I ultimately wanted to run a meaty setup so the Titan 7s I picked are actually Infinity Q50/Lexus ISF Spec. They do not list this as a Lexus ISF application anymore for some reason but it was listed as ISF specific last year.
These rims are NOT hub centric so you would need hub rings, I believe the bore is 73.1, the offsets are VERY conservative.
I have attached as much photo as I can to give you guys a good look about how it sits. Lug nuts are project kics r40 neochrome and tires are Michelin PS4S if anyone is wondering.
Thanks
Thanks
They look really good on stock suspension. Thanks for sharing pics!
Forum sponsor actually carries a similar set in 19" that's for the GSF/RCF in 60.1mm bore. But I think those offset (19x9.5/10.5 +32 all around) may be a little too aggressive for stock suspension though. Your offsets look perfect on stock body.
https://www.clublexus.com/forums/cl-...-in-japan.html
Thanks, yes the GSF/RCF specific TS-5 may not fit my tire setup with stock suspension and camber.
A 295 Michelin or Toyo would be about an inch wider than the Firestone 295. It's crazy that tire companies can get away with that.
Steve
Steve
ModInJapan
CL Vendor Products for IS-F
04-23-20 01:04 PM
lobuxracer
Wheels and Tires Classifieds
14
11-07-16 08:57 PM
ExclusivIS
13
05-22-10 04:22 PM
