Mark Levinson on the GSF
#31
Hey Finn,
Sorry I didnt see your post and its been a while now.
I believe they installed the speakers with the Focal Crossovers.
I just replaced the speakers only. The ML system have plenty of power.
#33
Yes they are 2 ohms.
Sorry I dont know about the impedance part. But I didn't hear the installer mention anything about it.
Gold10460 (07-23-20)
#34
Thanks, I was just curious. I also was not 100% satisfied with the ML sound although it is excellent as far as oem systems go in my opinion. I think the biggest bang for the buck improvement you can make on it is to add a subwoofer to make up for the lack of low end. I did this and am pleased with the results. It makes a pretty big difference in the overall sound.
MOB561 (08-25-20)
#35
I replaced the entire front stage in the GSF with JL CS5 and the rear doors with CS3 and while they're 4 ohm (couldnt find 2 ohms I liked) the sound improved drastically.
However, having come from a custom sound system that had a JL 12TW3 and a 500W JL mono amp, this system is a major disappointment in the thumping department. But I am learning to live with it.
#36
IMO the problem is how the OE ML system crosses the sub. Its way too low (I think its somewhere around 60 hz?) so you dont hear/feel it at all. I explored the idea of putting an aftermarket JL with its own outboard amp, but it didnt work out. We tried using an audiocontrols and it wouldnt work. The only way I think I'd be able to pull it off is if I go all in and use an LC8i or FiX, recombine and flatten the entire signal, then send it to outboard amps/dsp. If I wanted to do that I would not have bought a car with the ML system, but I have never seen a GSF without it.
I do miss my 12inch P2 punch, but in return i got alot more truck space.
And yes I am also disappointed with the stock ML system.
#38
#39
wait wait wait, explain please!
Im in SATX now, so a bit closer than before but not much. I did the c5 (500) and c3 (300) and c2-400x in the center dash (100). Soundskinned pro all 4 doors (300 materials) and around 300 in labor. So, a large chunka change but worth it since I put around 5K miles in four months...
#40
Tech Info Resource
And I drive around with the sound system off most of the time...
#42
Not sure if you can see it from the pic. The sub is spliced into the pink + and red - of the front speaker for a full range sound to the sub. I originally had it hooked up to the other red and white seen lower in the pic (factory sub out) but it sounded like crap. It was as if my sub had a low pass 50hz crossover on it with ZERO midbass. It’s much better this way although not perfect.
I also noticed quite a bit better bass with the sub facing the trunk lid and fairly close to the trunk lid although I have not found a good way to mount it in place yet.
Lee350F (03-01-21)
#43
I drove the latest A6 (2019) with its B&O surround sound system. Compared to ML on my GSF, B&O definitely has a lot more bass and surround, which means the sound is a lot more processed. I know a lot of people are into that, so if you like that type of sound, ML doesn't fit you. ML provides a very clarified sound so it does not add too much processing on it. That means you need a truly good source, and you need to tune up the volume a little bit more to hear the difference. Yes I agree that most people would love something easier to feel. Most of my friends would say A6 has a better sounding system and I don't disagree, but I personally don't want to hear the bass coming out of nowhere when listening to classical music.
#44
Turn off the surround and I've noticed that bass and mid goes up, but the treble/vocals I can hear behind me as well.
#45
Which car are you talking about? I heard people say new ES can only be heard from the front. I have tried that car but I didn't feel it's all from the front. On my GSF I tried surround on/off and I can't feel too much diff. I'm not too good at listening tho.
