Anyone experiencing clunky gearbox/fuel pump issues?
Old Jan 9, 2018 | 06:21 AM
TexasGSF's Avatar
TexasGSF
Default Anyone experiencing clunky gearbox/fuel pump issues?
I have 2016 GSF with about 13,000 miles and starting noticing my gear box is a bit "clunky?" I notice it the most when I press the gas to accelerate from idle. I compare the feeling to a clutch thats not grabbing/slipping.
Note, I had to take my car in a month ago, due to issues with my fuel pump...not sure if the fuel pump has anything to do with it....dealership fixed the issue by resetting/reprogramming my ECU. Does anyone else experiencing this/similar issues?
Old Jan 9, 2018 | 08:19 AM
gsfdream's Avatar
gsfdream
on my 16 i have 9k but have not noticed any of the symptoms you describe.
what was happening with your fuel pump that had you bring it in?
Old Jan 9, 2018 | 09:42 AM
mdrx350md's Avatar
mdrx350md
I have 26,500 miles on mine. Had a whining issue within the first 2-3,000 miles but was fixed with the software flash. The only other issue I've had was the squealing sound on the driver's side door from the door rubber gasket rubbing. I don't really care and will leave alone.
Old Jan 13, 2018 | 06:16 PM
McP's Avatar
McP
have the same noise on the driver door, also had the software update at 5k miles, haven't had any gearbox issues though
Old Jan 13, 2018 | 06:34 PM
anbark22's Avatar
anbark22
Have 9,100 miles on mine. No noises of any kind. Hope you get to the bottom of it.
Old Jan 17, 2018 | 10:14 AM
Htowncory's Avatar
Htowncory
Can you elaborate on the driver door noise?
I get a noise when I pull the door closed, kind of like a popping noise from the door pull handle.
Is that what you are getting?
Modenaro
Dec 11, 2018 08:47 AM
LoveSCs
Sep 24, 2017 08:45 AM
DavidL
GS F (2016-present)
21
Sep 15, 2017 12:14 PM
keithS
RC F (2015-present)
57
Nov 13, 2016 01:36 PM
Lexcalibre
Mar 7, 2016 05:34 PM
