GSF Wheel Spacers
Old Sep 21, 2021 | 02:16 PM
  #61
kukudm's Avatar
kukudm
Originally Posted by Jasoneo5
I have 15mm front, 10mm rear spacers with studs in (no need to replace OEM studs) on OEM wheels w/ stock height. Perfect fit, especially with my 265/285 Michelin XL tires
Where did you get the 10mm spacers with integrated studs? I looked up many places online, was only able to see 15mm + integrated studs.
Old Sep 21, 2021 | 02:33 PM
  #62
iamtwon's Avatar
iamtwon
Originally Posted by RATEDF
It's easy. Hammer the old ones out, and insert the new ones in. put some washers on the stud and lug nut and torque it down to the hub till the spindle is fully seated.
Thanks fam! Got me feeling like doing it now.
Old Sep 22, 2021 | 03:11 AM
  #63
designo's Avatar
designo
15mm is the minimum for spacers with studs integrated.
Anything smaller and it's a plain simple stud replacement.
Old Sep 22, 2021 | 12:35 PM
  #64
lobuxracer's Avatar
lobuxracer
Tech Resource
If you don't like your wheel bearings, use a hammer.
Do yourself a favor and buy a cheap ball joint remover from Harbor Freight for $20. It won't dent the ***** in your wheel bearings like a hammer will.
Old Sep 22, 2021 | 01:05 PM
  #65
RATEDF's Avatar
RATEDF
Hub components will not be damaged using a hammer. Ball joint remover applies force to the same point of impact.
To protect the threads on your studs from either ball joint remover or hammer, thread a wheel nut on the stud.
Old Sep 22, 2021 | 01:14 PM
  #66
lobuxracer's Avatar
lobuxracer
Tech Resource
Try hammering on any bearing and tell me it doesn't affect service life. The separator applies zero force to the bearings. All the force is on the hub face and stud. Might want to take a peek at the thread I linked.
Old Sep 22, 2021 | 01:19 PM
  #67
RATEDF's Avatar
RATEDF
You are correct. Using the separator is safe and won't cause any premature failure.
Old Sep 22, 2021 | 01:22 PM
  #68
1A1's Avatar
1A1
Def want to use a separator to pull the old studs and also a wheel stud installer for the new ones. There are plenty of good videos on youtube.
Steve
Old Sep 27, 2021 | 01:48 PM
  #69
Windows204's Avatar
Windows204
Originally Posted by designo
I'll take a clear pic today.
Maybe this video might help
https://youtu.be/g-VICMg8Lkg
Nice, and these are on stock springs? Not sure if I skipped over the answer in other comments.
Old Sep 28, 2021 | 12:46 AM
  #70
designo's Avatar
designo
No, lowered on RSR springs.
Details are in my signature.
Old Jul 22, 2023 | 06:53 AM
  #71
Pchou06's Avatar
Pchou06
10th Gear
Originally Posted by IsfClyde
This is with 20mm all around no rubbing issues
what tire size are you running in the rear?
uchujin
Sep 29, 2019 11:04 AM
rgonza1
Apr 4, 2015 08:34 PM
05ES330
Wheels, Tires & Brakes Forum
Jan 26, 2006 03:07 PM
gs4to4
Suspension and Brakes
13
Aug 1, 2001 03:53 AM
sleepybobcat
RX - 1st Gen (1999-2003)
May 14, 2001 07:35 AM
