GSF Wheel Spacers
Old Oct 20, 2020 | 05:41 AM
  #46
1A1's Avatar
1A1
Originally Posted by Iseluby
Anyone running just 15mm in the front? I’m lowered on Swift springs. Back looks fine but fronts need to be extended. Anyone having suspension issues due to the spacers?
15mm will fit just fine on stock rubber. You shouldn’t have any suspension issues but there is a chance you could wear out wheel bearings quicker due to moving the wheel out. More load will be in the outside of the bearings. I’m running 20mm front and back with Swift springs. No issues at all.
Steve
Old Oct 20, 2020 | 11:12 AM
  #47
TrevorR's Avatar
TrevorR
You'll have suspension issues if you track the car, but like 1A1 stated, you can wear out bearings quicker.
Old Mar 14, 2021 | 08:18 PM
  #48
jcg0324's Avatar
jcg0324
I just spaced my wheels. Thanks to all of you now the cute girls are looking at my car.
Old Mar 14, 2021 | 11:15 PM
  #49
designo's Avatar
designo
Once again, for reference only.
The car looks super planted and fat from behind.
25mm Front
20mm Rear
Old Mar 15, 2021 | 11:51 AM
  #50
D1GP's Avatar
D1GP
Whether using 20mm or 15mm spacers, is there a need to trim down the OEM wheel studs?
Old Mar 15, 2021 | 02:56 PM
  #51
Dukeaudio's Avatar
Dukeaudio
You’ll actually need to replace oem studs with longer ones.
Old Mar 16, 2021 | 09:30 AM
  #52
D1GP's Avatar
D1GP
for both 15mm and 20mm?
Old Mar 16, 2021 | 09:33 AM
  #53
Iseluby's Avatar
Iseluby
Yes. Mine came with the spacers.
Old Mar 17, 2021 | 09:09 AM
  #54
Meraki Autoworks's Avatar
Meraki Autoworks
Your #1 Lexus Vendor
We have spacers with the studs built in, the H&R DRM ones.
-Josh
__________________
Orange County, CA
Text/Call: 213 394 2886
Old Mar 17, 2021 | 09:53 AM
  #55
D1GP's Avatar
D1GP
-Josh
Hey Josh - For 20mm do I need to shave down my oem studs or will it sit flush to the spacer?
Old Mar 17, 2021 | 10:41 AM
  #56
RATEDF's Avatar
RATEDF
You'll need to install extended studs. Extended studs come with the H&R DRS spacers.
You're adding a spacer on the hub/existing studs, so you'll have less stud length to add the wheel and lug nut, hence the requirement for an extended stud.
Old Mar 17, 2021 | 07:58 PM
  #57
Jasoneo5's Avatar
Jasoneo5
I have 15mm front, 10mm rear spacers with studs in (no need to replace OEM studs) on OEM wheels w/ stock height. Perfect fit, especially with my 265/285 Michelin XL tires
Old Mar 17, 2021 | 09:01 PM
  #58
Dukeaudio's Avatar
Dukeaudio
If i recall research correctly from when i installed mine (20/15mm) rule of thumb at least same amount of thread engagement as width of stud.
Old Sep 21, 2021 | 01:20 PM
  #59
iamtwon's Avatar
iamtwon
Default New Studs
What's the install like for new studs? Do you need to press them? How easy/difficult is this going to be?
Old Sep 21, 2021 | 01:59 PM
  #60
RATEDF's Avatar
RATEDF
It's easy. Hammer the old ones out, and insert the new ones in. put some washers on the stud and lug nut and torque it down to the hub till the spindle is fully seated.
