Push to downshift, pull to upshift mod
Old Feb 3, 2025 | 07:48 AM
cyfi66's Avatar
cyfi66
Default Push to downshift, pull to upshift mod
Unlike most I actually enjoy using the shifter in manual mode to go through the gears, but the push to upshift and pull to downshift always annoyed me. It feels so unnatural and I much prefer pulling the shifter to upshift and pushing to downshift.
You can easily change the behavior by switching two wires in the center console/shifter area. I used this guide to remove the shifter trim:http://www.clublexus.com/forums/gs-4...sassembly.html
If you have small fingers you can remove the connector without pulling the entire center console. I got mine disconnected with a pocket screwdriver and a pick.
Connector located here
You will need to de-pin and swap the white and yellow wires.
Use a pick to lift the terminal locking tab
Use the smallest pin you can find to depin the connector
Lift the white plastic tab with the pin while pulling the wire out of the connector. It will release.
Re-lock the locking tab and this is what the wiring should look like now. Re-connect and reassemble the center console
Old Feb 3, 2025 | 10:15 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
Good info. I've never bothered with the GS F since it's the wife's car and I never use manual mode on it.
I don't recommend using a pin for this. Too easy to damage the connector body with the point. I took a stainless steel turkey lacing needle 1.4mm in diameter, squared it off at 1mm, flattened the end, and made a bevel on the end just like the Toyota manual says to make the tool. I did the same with some aluminum welding rod, but it doesn't work nearly as well as the stainless steel one does.
They also have three special pin tools 09991-00500, 09991-00510, and 09992-01030. I've never needed any of them in my 40 years of working on Toyota/Scion/Lexus vehicles.
Old Feb 14, 2025 | 10:45 PM
designo's Avatar
designo
I gotta hand it to ya..... that's the best piece of info I've seen on CL in a while.
Great work @cyfi66
EAST
Mar 1, 2025 06:34 PM
ch99tj
GX - 2nd Gen (2010-2023)
May 23, 2023 04:45 PM
007
ES - 7th Gen (2019-2025)
26
Apr 5, 2022 11:23 AM
EJC
Apr 5, 2010 05:45 AM
GSXRAWD
GS - 1st Gen (1993-1997)
Feb 11, 2004 02:05 PM
