Spoilers
Old 10-03-18, 09:44 PM
UDel
UDel's Avatar
Originally Posted by lamikela1
As far as I know it's either F-Sport or regular GS. I do not think that there is a difference between the Lux or non-Lux GS.
I basically want a spoiler that is larger then those small F sports I have seen linked, would prefer not to take the emblem off like you have to do for the Wald or knockoffs. What you have seems nice or something like it.
Old 10-03-18, 11:08 PM
rj4510
rj4510's Avatar
I put the non-f spoiler on my Lux edition. Read how so many have had great success with tape and considered it seriously. My wife took her car (13 RX) to the car wash and the system cleanly yet completely removed the driver’s side molding, which was taped on at the factory. Only one end was attached and it had a bolt. I know everyone just cringed with my car wash comment, but we get monsoons here in AZ and it gets super hot. If I need to meet a client, the car is going through the car wash, so figured factory bolt on method was best.
Old 10-04-18, 04:07 AM
Knucklebus
Knucklebus's Avatar
This spoiler is an OEM Lexus that bolts on. It's the one I'm considering.
You could remove the studs and just tape it on with the good stuff.
https://www.ebay.com/itm/Lexus-GS350...3/322035459432
Old 10-20-18, 02:01 PM
UDel
UDel's Avatar
I am still looking at spoilers but will likely order soon, will also be painting it myself. Anyone have any tips or experiences using dual sided tape, anything you learned to do or not to do as that will be the way I attach it. I definitely don't want to drill holes in my trunk.
Old 10-21-18, 08:22 AM
rj4510
rj4510's Avatar
The biggest issue with tape is if you don’t do it right, you had one shot. Preparation and using the right quality materials is key. Plenty of YouTube videos on taped on spoilers. What made me squirrely on tape was when the factory installed trim pulled right off on my wife’s car as mentioned above, so I guess someone messed that up even at the factory? Don’t know, our car was a lease return, so who knows, but the door has not been repainted, so can’t chalk it up to a shop screwing it up. That’s one story against tons of successful installations though.
Drilling isn’t as scary as it sounds either. Still comes down to proper prep. You use a template and seal the area with industrial sealant, just as it would be at the factory. The spoiler on my GX was installed and drilled at the dealership in 06. I sold the truck in 16 and no issues whatsoever with rust. I can’t imagine tape staying on as long, but that’s just me. I’ve seen plenty of trim fall off after years, but there’s been improvements in adhesive technology too. It’s all about weighing options and doing things the right way and not cutting corners or being rushed either way.
Old 10-21-18, 10:28 AM
eddie420
eddie420's Avatar
Clean entire trunk lid with soap and water, dry it, then use isopropyl alcohol to clean the spoiler area, let dry, then use 3M double sided tape generously throughout, and you should be done. I'd suggest using a clamp like this to keep pressure on it for a while. http://a.co/d/bQzHx5v
Old 10-21-18, 03:14 PM
rj4510
rj4510's Avatar
When using tape, the factory spoiler has two cuts per side, right where the trunk line meets the spoiler. They look like the tape is short in those parts, but they are short to allow a gap for water to drain. If you don’t leave the same drainage channels, water will either puddle up on the trunk, or sit across the tape lines inside the spoiler. can’t imagine that being too good in a freeze.
patnatty
12-16-16 05:19 PM
LeonHuu007
03-11-12 09:41 AM
chuckb
05-01-06 03:37 PM
Lettuce
06-06-03 08:20 PM
SanjayGolf
IS - 1st Gen (2001-2005)
01-29-02 03:13 PM
Quick Reply: Spoilers
