TPMS not in sync with standard tire pressure gauge?
Old 05-11-17, 06:47 PM
iWannaGS
iWannaGS's Avatar
Default TPMS not in sync with standard tire pressure gauge?
I had to deflate my tires today due to increased pressures with the summer heat. I took them down to 32psi after I checked them with a non digital tire gauge. After I finished I turned on my car to check the TPMS and I saw that they were showing 30psi. I then rechecked with the tire pressure gauge and it read 32psi. Therefore which one is accurate? Do I need to reinflate my tires a bit or would I just need to drive my car to let the TPMS officially recalculate? I went into settings and resettled it as well. I haven't driven my car yet, just washed and it's been sitting in the garage.
ps. What is a good non expensive digital tire gauge you all recommend? Or should I go with a non digital one?
thanks
Old 05-11-17, 06:55 PM
bclexus
bclexus's Avatar
Received 1,996 Likes on 1,418 Posts
My TPMS readouts are extremely accurate. I use a digital air pressure gauge to compare the TPMS readouts that I know is accurate because it compares exactly with a known 'lab calibrated' gauge.
Old 05-11-17, 06:59 PM
iWannaGS
iWannaGS's Avatar
what pressure gauge do you own?
thanks for your input
Old 05-11-17, 07:43 PM
bclexus
bclexus's Avatar
The little inexpensive (~$5) digital gauge I use is a Accutire MS-4400B, which matched perfectly with a very expensive 'lab calibrated' aviation gauge.
RiojaRed
09-25-17 11:54 AM
pbxcomm
08-16-16 01:34 PM
jkeifer3
RC F (2015-present)
10-12-15 11:24 AM
DJWLDW
07-28-15 05:28 AM
Mike_TX
06-15-08 02:46 PM
Quick Reply: TPMS not in sync with standard tire pressure gauge?
